My Pioneer vsx 9500s stereo receiver wont play any sound out of it. I have all the cables and speakers connected correctly but I can't seem to find whats wrong. Help please anyone?
3 Suggested Answers
  • 63 Answers
SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Posted on Aug 03, 2007
AJIN G
  • 6694 Answers
SOURCE: pioneer audio video receiver VSX-D710S but there is sound to the speaker, but no audio coming from the player
Try to check the audio setting of the player. If you user using optical or coaxial then the audio out put format setting should be Raw other wise it should be PCM. You will see the setting if you go through the menu of the player
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
Where can I obtain a free Owners Manual for a Pioneer VSX 505S Stereo Amplifier?
The support section of the Pioneer website would seem like a good place to begin and failing that I am sure you will find a specialist forum.
What you are proposing to do I think, is to connect two speakers to each of the two remaining working outputs.
Connecting two speakers in parallel will tend to make the amplifier think it is one speaker of a reduced impedance into which it will attempt to deliver more power for a given volume setting. If you like your music loud you could soon overload the output stages.
Connect two speakers if you like but if you don't want to stress your amp you should set the volume control to half of your usual setting, when you could discover your disatisfaction with the arrangement or if the amp is a well-designed tough unit you might just get away with it.
Alternatively, you could take it to the repair shop and get it fixed.
Apr 29, 2016 | Pioneer VSX-505S Receiver
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
Plays only mono when listening to music
I lot could depend on how the music source has been connected to the receiver. If you are using a stereo CD player then you may need to check if it is configured to send audio in stereo mode and not mono. The input source selection for the audio is given in page 26 of the manual.
You can go to the setting menu in Receiver and configure the speakers settings according to which ones you have installed.
Also refer page 25 in the manual to over ride speaker configuration if it is not showing correct.
VSX 826 Pictures support downloads Pioneer Australia
Aug 22, 2014 | Pioneer Vsx 826 K Av Receiver Black
No surround sound
Review the speaker set up instructions to determine whether the correct sizes have been selected. In some speaker configurations, signals are mixed or redirected to compensate for size limitations and other factors.
Mar 19, 2014 | Pioneer VSX-2016 7.1 Channels Receiver
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
Rear speakers on vsx1122 not playing, they tested okay
Manually change your surround settings for your satellite box input. Your box may not be putting out a signal that the receiver auto-detects as a surround sound signal, thus it just plays in stereo.
Dec 26, 2012 | Pioneer VSX-1122-K Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
143 people viewed this question
 Grubhead
Grubhead
