I have vista and im trying to run Teamspeak the program starts and runs fine but when i press push to talk there is no sound also i have turned off UAC so dont need admin rights to run program any ideas
  • thetrooper44 Jan 12, 2009
    Yes i can hear people but cannot talk i am quite good with finding way round computers bu this one go me baffled lol
  • thetrooper44 Jan 13, 2009
    Its ok Guys i have cured it..it was driver issue for mainboard was only xp compatible but now i got right driver thanks for trying to help
  • 326 Answers
Check its setup right for your sound card and the push to talk is set to the button you want, ive had this problem and it was just the settings in the program. can you hear ppl ok?
Posted on Jan 12, 2009
I just updated my computer from XP to Vista and i used to use Teamspeak 3 all the time now windows vista 32 bit won't load it!!! Please help!
You may be able to right click on the installation file and hit Run in compatitibility mode and select WINDOWS XP.
Aug 05, 2013 | Computers & Internet
Virus
Restart your computer and before it says "Starting Windows" (XP, Vista or whichever version you have), press the F8 function key on your keyboard. You'd get a menu. Select the "Safe Mode with Networking" and press Enter.
Once Windows boots into safe mode, try to run the programs now. If they run fine in safe mode, download Malwarebytes .
Then, update and run this anti-malware program. It will remove any virus / malware. Once this is done, reboot your computer back normally and the programs should work fine.
Hope that helps,
Regards,
Raspal
Mar 25, 2010 | IMSI TurboCAD Deluxe 10 for PC
Internet audio output becomes input echoing back out thru PC
try unmarking the "listen to" option on your sound devices panel. it should remove the echo
Feb 06, 2010 | Logitech Webcam
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Speakers feedback through my Barracuda Mic
if have a camera already connect on your pc try to unplug the mike of your camera or go to the audio device manager and change the settings.
Jul 06, 2009 | Razer Barracuda Gaming Headset
Error code 113 move data
Im no games expert im afraid,but it sounds like its trying to install to the wrong location.
For example;
Check it is installing to something like "C:\Program Files\tigerwoods"
What is your operating system,ie Vista/XP etc
From what i can see,these are old games and may not run on Vista (assuming you are using Vista) .
But may run in compatibility mode ;
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
If Vista,also right click the .exe and run as administrator.
Feb 09, 2009 | Sierra Sports PGA Championship Golf for...
Vista
if you do not have the installation disk you are out of luck, unless you can borrow some ones, removal of operating systems is reletively easy, to need to know which one your are currently connected with, going to the start menue and run the folowing click run, type %windir% and click ok, write down the folder that is open, do not touch that folder if you want to keep that operating system, otherwise your dead, go to microsoft website its all there for you to download and follow the directions, not to hard at all. good luck
Dec 23, 2008 | Microsoft Windows Vista Home Premium with...
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Teamspeak Won't Work with Vista
Look at TeamSpeak overlay with PlayClaw. The main task of PlayClaw is to record game video but it have ability to show Teamspeak & Ventrilo overlays. Works fine with Vista/W7, but only one restriction - voip client must be 32 native (not 64) app. Windows may be in any bits: 32 or 64
Nov 21, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
