Question about GE JTP27 Electric Double Oven
Lower oven heating element burned up
I am having great difficulty in locating a manual for my JTP27W0A3WW double oven. The lower oven heating element burned up last night. Where do I go now?
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Lower element on GE Profile electric convection oven went out
Although this is an easy repair, the element is not a real common one so many service / parts stores may not have the WB44K5018 in stock. Make sure to get on finding one fast to make T day go smoothly. Here in the midwest I use C.E. Sundberg for a lot of my parts, as they have a good stock and are fast. (they have this part on hand at their main branch in Chicago and at Omaha, Fargo, and St. Louis Park (MPLS). The repair is essentially: Turn off power. Remove two 1/4 inch hex head screws. Pull element forward a couple inches into oven cavity to access the electrical terminals. Remove push on wires from old element. Install new element. One of the easier repairs.
Posted on Nov 23, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
SOURCE: Is it easy to replace the lower element on a jtp
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Posted on Apr 13, 2009
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Lower element does not heat up.
did you test it? could be bad. may be relay board, burned/broken wire, safety thermo or a bad solder connection on the board.
Feb 01, 2014 | Thermador SM272 Electric Double Oven
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
GE JTP27 Electric Double Oven Logo
105 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
