Question about GE Dryers
Where is the thermal fuse located on ge dryer dcl333eaoww
catriver
  • 878 Answers
SOURCE: Thermal switch location
On a series 10, it's located behind the bulk head, behind the drum. On a series 11 they moved it to a bracket on the heater cone. Catriver.
Posted on Jan 01, 2008
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
appldoctom
  • 311 Answers
SOURCE: location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Posted on Dec 31, 2008
TheMobilian
  • 8220 Answers
SOURCE: location of the thermal fuse on the kenmore gas dryer 80
Posted on Feb 04, 2009
  • 492 Answers
SOURCE: where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Posted on Apr 30, 2009
Where is the thermal fuse located on this dryer? please
Hello Leslie
I don't know what is the brand of you dryer. I will make you a preference this brand.
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. To access the thermal fuse you will need to open the dryer from the top. Though it may sound a bit daunting, opening the top of the dryer to reveal its inner workings is surprisingly simple. To open the dryer top you will need a flat-head screwdriver, putty knife or similar tool. Insert the screwdriver or putty knife underneath the dryer's top panel. Slide the putty knife along the bottom of the panel until you locate the two clips that hold it in place. These clips are usually located about four inches in from either side of the top dryer panel. Apply pressure to the clips to release them. Once the clips have been released, lift up the top panel and use the supports to keep it upright. Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing. The thermal fuse will be located next to the heating element housing. Look for a white strip with two wires connected to it and you've located the thermal fuse in your GE dryer.
Best Regards
Neciforo Llanto
Oct 01, 2013 | GE Profile DPSB620GCWW Gas Dryer
DWSR483GG WONT START
the thermal fuse located on the inside rear wall of the dryer to the right side of the heating element behind the drum is open,on any GE dryer of this type if this fuse opens it kills the whole dryer operation..........no nothing,nada
Dec 09, 2012 | GE DRSR483EGWW Dryer
GE DPSE810EG won't start
You will need to check and see if the dryer has a bad thermal fuse on it. If so, it will cause the dryer not to start.
The thermal fuse should read closed for continuity. The thermostat is number 507 on this diagram. It is located on the top of the heating element housing.
Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE Profile 7.0 cu. ft. Electric Super...
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
Dryer does not heat
My GE (model #:DCL333EAOWW) Dryer does not heat up and the timer on the dryer does not work. Does anyone know what I would look for to fix this problem on my own?
Jan 16, 2011 | Dryers
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Aug 14, 2009 | GE Dryers
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Dryers Logo
73 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
