Question about Samsung Refrigerators
Model rs2544sl. How can I reset?
The power went out when it came back on there is a blinking light on the display and frig dose not work
5 Suggested Answers
SOURCE: samsung model RS2577SL
That just worked for me too. Hold the power freeze and power cool buttons down at the same time and it will reset it after a power surge. All I had working was a light inside the door and a blinking green light on the display panel.
Posted on Jun 04, 2008
SOURCE: samsung SR-L626EV POWER WENT OFF BUT WONT RESET. ONLY ALARM SOUNDING AND GREEN LIGHT FLASHING ON CONTROL PAD
press and hold the 2 outside buttons( the quick freeze and chill)
Posted on May 30, 2009
  • 17 Answers
SOURCE: model rs2534ww side-by-side Samsung frig.
Regarding Samsung refrigerator model rs2534ww/xaa repair: Basic trouble-shooting from Fixya was helpful, but solution required service call from repairman. (Very few repairmen work on Samsung at this time.) We thought problem was the digital controller, but turned-out was ice maker (!). Repairman explained Samsung has wierd control design that is based upon ice maker sensor. Sensor alone cannot be replaced, required entire icer, which he had in the truck. Icer cost $105 retail ($86 online), but controller would have been $161 retail (couldn't find controller online). Hint: if control panel is "dead" except for (only) the upper (horizontal) LED segment of the right-most refrigerator temperature digit, the problem might be your ice-maker. If you find the ice maker online and can install it yourself, you can save at least $130.
Posted on Dec 04, 2009
imufo2
  • 3773 Answers
SOURCE: I have a Samsung frig;
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 27, 2011
Moved frig - was working, now only lights working. Digital display, compressor not coming on. 2007 model FSC23F7HSB
OOPS they tell us to never lay on side of back but if you do do not plug in for at least 24 hours so the oil can run back to the compressor .most likely you burnt the compressor out .
Jul 03, 2015 | Refrigerators
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
I have a Samsung RF4287HARS. I opened the refrigerator compartment doors and the lights did not come on. Same condition for the freezer. I believe that the unit is operating (as i could hear the faint...
Pc code is saying there was a momentary power loss. Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Thanks for Choosing FixYa. Kelly
Sep 29, 2010 | Samsung Refrigerators
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
Sep 19, 2009 | GE Refrigerators
Went to put groceries in frig and found it not on
yoor lights should be on at the very least, i would check the outlet , plug in a hair dryer or something, no internal lights means you have no incoming power supply
Dec 17, 2008 | Maytag MCD2257HES Side by Side...
Refrigerators Logo
286 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
