NeoniQ 18.5'' TV w Built-In DVD Player keeps ejecting disc
hardrocko
  • 1476 Answers
SOURCE: dvd won,t eject
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
Posted on Jun 26, 2006
  • 979 Answers
SOURCE: My built in dvd player doesn't work
I'm sorry, but it's shop time more than likely. One thing you may try though, is to unplug the set from the wall and wait 2 minutes, then try again. If that fixes it, Great! If not, well, refer back to the first statement...accordianman
Posted on Feb 29, 2008
SOURCE: 46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Posted on May 25, 2008
SOURCE: dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
Posted on Jul 09, 2008
  • 13 Answers
SOURCE: No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
Posted on Jun 10, 2009
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Coby tfdvd3295-32in720pwidescreen lcd hdtv with dvd player hdmi input
All TVs have a tuner and a set of AV inputs for connecting other sources. A combi TV such as the Coby has one of those inputs dedicated to the built-in DVD drive. Press the Input button to see the list of sources.
The disc can be ejected either by pressing the eject button on the set itself, or possibly from an eject button on the remote if there's one fitted.
Sep 03, 2014 | Televison & Video
I have a 19 inch Emerson tv with built in DVD player model LD190EM2 and it keeps ejecting DVDs. Whenever I put a DVD in it starts loading and then it ejects it back out.
Disc loading mechanism fault. Disc is not loading properly to its seating. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 10, 2014 | Televison & Video
We have a brand new LG TV with a built in DVD player. We put in a DVD and the message was "No Signal." DVD will not play. I cannot eject it from the player
Hi:
The only way to diagnose this problem is to take the DVD out and inspect the take up rollers designed to take and eject the disc. If you hear sound when try to eject you may have a bad belt or the take up rollers are oxcided causing slipage during ejecting.
Dec 23, 2010 | LG RU-44SZ61D 44" TV
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Disc will not eject.
Common cause for a disc not to eject is the loose belt from the motor to the gear that closes or opens the disc tray. You need a repair man to open it and change the belt.
Jan 03, 2009 | Polaroid TDM-1421C TV
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
"no disc"
try other cd's which you know it was working before. the cd you are playing might be defective wit scratches
Oct 06, 2007 | Apex Digital AD-1110W DVD Player
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
