Question about Gaggia Titanium Espresso Machine
Very slow water output
My machine is just a few months old but making a cup of coffee takes several minutes to drip out.  Not all the time but usually.  I can not figure this out I clean the darn thing all the time have put it through the cleaning cycle and it is good for a few cups then back to the drip drip drip.  Is this the norm for this make of machine.  I had a an older model different make before and it was wonderfully quick unitl the poor thing moved on.  Any ideas.?
  • michaelpc197 Jan 12, 2009
    Very slow coffee output !! Tried everything ..... HELP !
  • hanley_ca Jan 16, 2009
    The water is running quite a bit faster now and even though I was washing the unit I guess it just was not good enough!  Thanks again
Open door of machine & take Brew head out. You will see a cylinder shaped part which is black with an orange washer half-way down it. Look underneath this cylinder and you will see a steel disk,(which may look black) this is the filtre. Now look above the cylinder and you will see a turn knob, turn anti-clockwise untill the disk comes free. Hold the disk up to the light and you will see the minute perferations which are all clogged with coffee grounds, give this a thorough washing under running hot water ,( use the brush provided with your machine to push the grounds through. You will also need to blow through these holes very hard and often untill you can see that they are cleared. This should be done after about every 15 cups made. I got this info. from the Gaggia engineer and it works!! Good luck.
Posted on Jan 16, 2009
Very slow, 40 minutes to make 8 cups
Run a 50:50 mixture of cold water and white vinegar through the machine several times. Allow the mixture to cool off after each run and use a filter to catch the debris that comes out of the heater/pump. Run clean water several times to remove the vinegar taste. This works great on our old Mr Coffee and lasts for some time before doing it again. Hope this helps!
Sep 26, 2010 | Cuisinart DTC-975 Coffee Maker
Coffee drips slowly and water doesn't drain completly from filling chamber. had machine for about 6 months and was happy until today.All I hear is a humming, a slow drip of half a cup and then it shuts off...
mcdevito75 here, Your coffee maker most likely needs cleaning, Water will leave deposits in the brewings ports over time and will have to be cleaned out, Follow your owners manual on cleaning your coffee maker.
Jun 17, 2010 | Keurig B100 Coffee Maker
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
The machine is only a couple months old. It is
check grinder maybe is too fine ,go litlle bit courser and try
Jul 01, 2009 | Rancilio Silvia Espresso Machine
Very slow output to fill cup
You will need to Descale the Machines. Most likely calcium bulidup inside machine.
Jan 22, 2009 | Saeco Vienna De Luxe Espresso Machine
Ge coffee maker
Old message, you probably have had a few machines more by now.
If bnot, take it back; the bimetal thermal switch that is responsible for cycling the machine is 'bad.' Actually, it's Chinese and they haven't quite figured out how to make these reliable.
This type of switch has been around for 3/4 century and those made in the US were only used for protection and cycled only to prevent fire in some equipment. Because they are a sandwich of two metals, they flex to switch when their design temperature is reached. Just because of metal fatigue, they really aren't intended to switch off and on several times a minute as they must in a drip coffee maker.
Mar 01, 2008 | GE 106591 Coffee Maker
Braun Aromaster 10 coffee maker
time to descale the machine not with vinegar but with descaler product 1part descaler 1 part descaler fill the water tank put machine on for few minute stop it for few minute start untill empty rinse very good a few water container and that it if our coffee does not stay warm after that at the bottom of machineinside check the element contactsometime the contact overheat they get some corosion on less power go trus them = less heat i say not to use vinegar vinegar remove calcium in little piese you might block the machine descaler melt calcium thanks for using fixya pierre
Feb 04, 2008 | Coffee Makers & Espresso Machines
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
394 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
