Question about Hasbro MARVEL LEGENDS TRANSFORMERS CROSSOVERS - SPIDER-MAN
Instructions for Transformers black spiderman crossover
I have no idea how to help my 3 year old change his transformer into the action hero.
    Brigadier General:
  • 5,158 Answers
I'M actually getting an error on the page that has the instructions but here it is
http://www.hasbro.com/customer-service/toy-game-instructions.cfm
Robert
You can contact the company for the instructions as well or to ask them to fix that page so you can download them
Posted on Jan 12, 2009
Planning birthday party for my 3 year old grandson, with spiderman being the theme any ideas please
Sorry But you are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use
Jul 09, 2017 | The Toys
My tv powers on then the screen goes black
Hi
This is a common fault on this model, after a couple of years of use the capacitors that drive the inverter transformers go faulty and leak.
These need to be changed, remove the back from your tv and look at the power supply (top of tv) you will see 2 x transformers with white leads, just before the transformers you will notice 2 x capacitors that are bulged out on the top maybe with a brown like substance leaking out of them.
On the power board these should be marked as.... EC17 / EC18 OR C72 / C73
You need to change both of these. from what i remember they should be 10uf 450v.
Change these and you should have your picture back.
Please rate this with your thumbs up and any comments you care to leave.
Thanks
Oct 11, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
My monitor keepfading outand going to a black screen, please advise. It's only about 3 or 4 years old
3 to 4 years old are due time to look for bad caps in the power supply and inverter section,
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 12, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
I will charge my zip zap but wen i try control it it wont move
The transformers are maybe glued to the PCB.
Please watch out that it isn't a double sided PCB.
You can try to slip a thin object under the transformers, then you can feel if there is any glue.
Good luck,
Gerard
Jan 11, 2010 | DBX EQALIZER, DUAL 31 BAND, INPUT AND...
Olevia 30 inch no image blnks blue on turn on
Check the backlight inverter board (open winding of the transformers) and the power supply module for bad capacitors. I have LT30HV with the same problem and able to get the replacement transformers for my inverter board from LCDPARTS.NET. I also rebuilt my power supply with new capacitors since the set is more than 3 years old which will more likely to have capacitors problem later on.
Nov 06, 2009 | Televison & Video
Transformer Instructions available online??
good day,
hope this link below will solve your problem.
toys
Sep 05, 2009 | Hasbro MARVEL LEGENDS TRANSFORMERS...
Intex saltwater chlorinator not working. Checked
IF YOU HAVEN'T HAD IT A YEAR , RETURN IT TO INTEX FOR REPAIR
Jun 17, 2009 | Intex Automatic Salt Water System for ...
Transforming the incredible hulk toy
The legs were on backwards after much frustration, I figured it out thanks
Apr 09, 2009 | Hasbro Marvel Legends Transformers...
Some gmes won't play.
Ok. Do you have a NTSC system?
Some PAL games will only run on standard and some will only run in HD and some will run on both if the PS3 is NTSC. The PAL games output at (576i/p) while the NTSC outputs at (480i/p). So honestly, I think that is your problem. You have a NTSC system and PAL games. If you do not have a HDTV then you will need to exchange those games for the NTSC version. Sorry for the bad news. It's not Sony's fault, it's how the game developers coded the games.
I hope this helps. Good luck to you.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Hasbro MARVEL LEGENDS TRANSFORMERS CROSSOVERS - SPIDER-MAN Logo
895 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
