Question about Krups Kitchen Appliances - Others
Remove plates on krups waffle iron - Krups Kitchen Appliances - Others
SOURCE: Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Posted on Feb 09, 2008
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
farfield
  • 462 Answers
SOURCE: Dead krups waffle iron
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
Posted on May 06, 2009
  • 4 Answers
SOURCE: Repalcement plates for Model 270A Toastmaster Waffle Iron?
Actually I have a Toastmaster 270A waffle iron. It is much better quality than the later toastmaster models, and it is basically identical to the Black & Decker model G48TD, which is still sold. You could get plates from Black & Decker. The entire iron sells for $50.
Posted on Jan 03, 2010
  • 27 Answers
SOURCE: waffle iron light goes on gut does not heat up...
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
Posted on May 25, 2010
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
I have a swb7re waffle iron. What's the best way to clean it?
Hello, W/D here.
Not everyone will tell you this, but here's the best way. When you are finished with the waffle maker, the plates will be oily. That's good. Wipe down the outside of the appliance with mild soapy water, followed by clean water. Wipe down the plates with clean water only, just enough to remove any left over waffle material. Then, dry the plates with paper towels, or a soft cloth. You want to avoid detergent on the plates, as this strips the oil off which seasons the plates, making better waffles.
Best regards, --W/D--
Feb 10, 2011 | Star SWB7RBE Waffle Maker
The waffles stick and separate when I open the top
You really have to use a release agent, like pam. Waffles have a ton of surface area that needs to release.
Jan 24, 2011 | Krups FDD912-75 Expert Belgian Waffle...
I bought a Krups Household Type Waffle Maker at a thrift store. It looks new, but doesn't have any instructions with it on how much batter to use or how to clean it. I got a recipe online and it was great...
I think this is why people make pancakes. =) Cleaning the waffle iron is a real pain. My waffle maker looks exactly like the one you have pictured. Mine also came with no instructions because its my fiance's. As far as how much batter to use, you should use a ladle and through trial and error figure out how much is the best amount. I would guesstimate approximately 1/4 c. For cleaning the overspill, from what I have read online, everyone says to unplug the iron (obviously) and wait until the waffle iron has completely cooled before cleaning. I have cleaned the back of the unit (where the coils are, which unfortunately got flooded with batter the first time) with a damp kitchen brush, damp sponge, and paper towels. Its messy and time consuming to clean up. You can get in the coils better with an old toothbrush or a very small bottle cleaner (like the kind you would buy to clean cake decorator tips). I just use warm water to remove the batter/gunk. I use a sponge (damp with warm water) to clean the baking plates. I towel dry everything after its clean, and clean the outside with a little windex so it stays nice and shiny. Good luck! I also recommend making lots of extra waffles and freezing them, so you can avoid as much waffle clean-up as possible. ;) You can heat them up in the toaster like Eggos. They stay good in the freezer for up to 6 months.
Sep 21, 2010 | Krups 65475 WaffleChef Waffle Maker
I'm looking for the instructions that came with the Krups 653-73 two-waffle maker.
mcdevito75 here, BEST BET, contact Krups customer service at 800-526-5377 Hope this helps.
Jul 11, 2010 | Krups 653 Chrome Belgian Waffle Maker
Waffles are separating when we open the plates
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Jul 12, 2009 | Waring WW150 Waffle Maker
May 06, 2009 | Krups 65475 WaffleChef Waffle Maker
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Kitchen Appliances - Others Logo
43 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
