Question about LG Washing Machines
How do I remove the top of my LG WM2496HSM washer?
I have an LG WM2496HSM front load washer with an FE error code. I know this is for the water valve assembly, which I have ordered both, since I'm not sure which one is faulty, but how do I get the top off the washer!?@&! I have removed the screws on the back, bit it is not budging, what's the trick? Also, is there a way to know which valve is faulty by the code?
  • christiepatt Jan 12, 2009
    Thanks. I tried that, but it's not sliding. Any suggestions?
    Thanks, now I just need to figure out which valve needs to be replaced.
  • 1,543 Answers
Code will not tell which is faulty. To remove top: after removing three phillips head screws (leaving the L shaped part attached to the top) slide the top back about one and a half inches and lift it straight up.
Posted on Jan 12, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jan 12, 2009
    Ops, that was for the Dryer. The washer has plastic retainers on the back. Take the screws off the bottom side of those, leaving the plastic attached to the top, and slide the top back an inch and a half and lift it off.
    I usually use the flat side of my hands and slalp them back on the top of the washer (pushing back) near the front side on each side of the top. This should be a Fix-Ya for you washer.
Model Wm2496HSM will not spin and drain
Jodie, the OE fault is a drain problem. First thing to look at is the pump coin trap on the bottom of the washer behind the little door. If the washer has water in it, pull out the little hose, remove the stopped at the end and drain into a shallow bucket. When the water stops, removed the trap by twisting the trap handle counter clock wise. If it is full of "stuff" clean it and reinstall it. If it is clean, then you either have a bad pump or something stopping the pump.
Apr 10, 2014 | LG Washing Machines
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
My lg washer wm2496hsm displays a "te"error what is this
The water temp. thermistor is @ fault or the main computer.
Service will be needed.
Jan 20, 2010 | LG WM2496H Front Load
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
Dec 22, 2009 | LG WM2277H Front Load Washer
LG TROMM WM2496HSM MILDEW & MUST SMELL
I have had the same problem with mine. I have started taking the rubber seal off at least once a month to clean it with bleach and water. I would not recommend doing this unless you are handy with tools. You might try cleaning the seal with bleach and water while it remains on the machine. Careful to pull the inner sealing lip down to get to the "Slime" behind it. Good Luck
Jul 26, 2009 | LG WM-2277HW Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG Font Load Washer flashing error code FE
FE is Fill Error. If door is closed and washer is plugged in, FE means water is too high and water pump will turn on.
This happens most often when a water fill valve will not shut off completely, allowing water to continue to fill washer, sometimes very slowly. If you shut off one valve (where the hose comes from the household plumbing) at a time you may be able to tell which valve is the culprit. The hot is a single coil valve, the cold is a multi coil valve. Both are the part where the hoses connect onto the machine.
To access valves, remove 3 phillips head screws at the back of the washer holding the top cover in place. Slide the top back about two inches and lift it off.
Oct 12, 2008 | LG WM-2277HW Front Load Washer
FE code displays
Yes, the water valves are easy to locate and replace.  Just remove the top panel to get access to them.  There are 2 of them.  You need to know which one to replace before ordering the correct part from LG.
Mar 05, 2008 | LG WM2277H Front Load Washer
Washing Machines Logo
399 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
