Question about Monroe Classic Calculator
My Monroe 4130 calculator will only print in red.
I just put a new Nu-kote BR113N ink ribbon in my calculator but it is only printing in red. The ribbon has red on the top and black on the bottom. Please help.
5 Suggested Answers
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
SOURCE: Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Posted on Apr 22, 2009
  • 5 Answers
Have you remove the tape that used to fix the ribbon cartridge since the time you get the Monroe 7130? If you do remove the tape, please try to take out the Ribbon Cartridge and install it again, by refer to the description of 'Changing the Ribbon Cartridge' in the Instruction Manual. The printer lift may stuck and need to adjust.
Posted on Jan 27, 2010
lbrown1806
  • 488 Answers
SOURCE: the ribbon will only print red ink
While in the D position or PD position, N Count
is OFF. In the N Count N position every
Plus, Minus, Equals Plus, Equals Minus,
Memory Plus or Memory Minus key depression
is counted. The Accumulator and its N Count
or the GT N Count can be printed by
depression of the Subtotal or Total key. When
either Memory Subtotal or Memory Total is
depressed, Memory N Count will print. N Count
is always printed in red, left justified. If the
Equals key is depressed immediately after the
Subtotal Total, Memory Subtotal, or Memory
Total the average of the entries is printed.
When the N Count prints on the 7150, an audit
symbol will print to the left of the N Count.
The audit NA will identify the Accumulator
register N Count, NG will identify the GT
register N Count and NM will identify the
Memory N Count.
Posted on Apr 24, 2012
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
The ribbon will only print red ink
Memory N Count.
Apr 23, 2012 | Monroe 7130 Calculator
What ribbon cartridge do I use for HR-8TM Casio Calculator
  • Nu-Kote NR42 Compatible Ink Roller
  • Single-Ply Adding Machine/Calculator Roll, 16lb, 2-1/4"x150
Mar 04, 2011 | Casio HR8TM Calculator
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
Need new ribbon
The ribbon code is BR80C. Nu-Kote has a version with a part number of NUKBR80C. You should be able to order it on line at Staples.
Mar 27, 2009 | Sharp EL-2630P Calculator
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Need users manuel
Call Monroe and ask them how you can get a manual. Otherwise Google to see if you can find any website that archives manuals has it for download
Oct 30, 2007 | Monroe 7140 Calculator
Monroe Classic Calculator Logo
626 people viewed this question
Top Monroe Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Monroe Office Equipment and Supply Expert? Answer questions, earn points and help others
