Canon IRC 6800 error code E000061-0005 - Office Equipment & Supplies
2 Suggested Answers
SOURCE: canon irc 3200 error code E000001-004
Want to print a Microsoft Office Publisher document to Canon iR C3200 and it gives'
me this message: Cannot continue to print as the disk is full. I have plenty of room on
my drive and so does the copier. Please advise
Posted on Oct 21, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon iRC 5185i with the erro code E000007-0201 . i need solution
Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
Oct 25, 2013 | Canon iRC 5185i
IRC 3380i error code E000001-0003 please help
get into service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
Sep 03, 2013 | Canon C3380i Color Copier
Canon copier irc 6800 shows an error e000800-0001 pls help
It is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the issue. Another thing to check is the upper fuser roller for flat spots this can also cause fuser error codes
Jun 03, 2012 | Canon Office Equipment & Supplies
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Canon IRC 2570 IC Error Code is E000012-0002 problem what is the solution
May 22, 2011 | Office Equipment & Supplies
E0012-001
i know this is in english but the e012 code is the Drum/ITB drive motor has locked up and has stopped turning and needs to be checked and or replaced.
Jun 02, 2010 | Canon imageRUNNER C6800 Copier
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
71 people viewed this question
jasbo
jasbo
