Question about Reebok Exercise & Fitness
I own a Reebok V8.90 treadmill and it will not incline?
Reebok V8.90 treadmill, it will not incline, it doesn't even make a noise like it is trying, I haven't had it very long, any ideas?
jgwhomeequip
  • 1902 Answers
SOURCE: Reebok 8500 ES treadmill - noises
You should check the motor and the rollers. There are oil joints that can possibly use some oil or the motor is going bad. The way to check the motor is with a volt meter or to check it with your hand after running it for 5 minutes without a load on it. If it is very hot then replace the motor. Most noise problems come from the rollers bearing which usually just need to be oiled and not replace. There is a cover behind the big roller that can be removed to look at the problem
Posted on Feb 11, 2009
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
greenspan
  • 1734 Answers
SOURCE: incline wont work
Check here for the user manual:
http://manualfox.com/link/reebok.htm
And maybe send them a manual request?
Posted on Jul 06, 2009
SOURCE: Reebok REM 11300 have moved my treadmill, it has
I had the same problem, this is how you fix it.
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
Posted on Aug 30, 2009
How can i order an incline sensor for my REEBOK RX 6200 treadmill?
will this one work?
https://www.treadmilldoctor.com/reebok-incline-sensor
Mar 09, 2018 | Reebok Exercise & Fitness
Incline not working on Reebok ZR9
If you wish get some details about treadmill repair check the link below
www.electro-medical.blogspot.com
Jun 30, 2016 | Reebok Exercise & Fitness
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Hello - when I turn on my reebok treadmill, the only buttons that work are start and incline (incline works most of the time). All of the other buttons do not work. Its a Reebok Vista RBTL13305 model...I...
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Aug 14, 2011 | Reebok Vista Treadmill - RBTL13305
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Mar 01, 2010 | Reebok 8050 ES Treadmill
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Treadmill wont incline all the way
With the key in the console, press one of the incline buttons. While the incline is changing, remove the key. After a few seconds reinsert the key. The treadmill will automatically rise to the maximum incline level and then return to the minimum level. Thi will recalibrate the incline system.
Sep 30, 2009 | Reebok 8050 ES Treadmill
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Exercise & Fitness Logo
66 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
