Candy gow475 Hello. Shortly after set dryer start flashing 'Stain Blaster' button and program stop working and can't open doors until switch to OFF position ? 8 weeks old machine, proper leveled and proper wash. Pls advice.
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
Posted on Jul 27, 2010
KevinWhite
  • 1902 Answers
SOURCE: my candy alise washer dryer
Hello & Welcome to FixYa
The problem is with the door lock-switch assembly not working, the unit detects that the door is not closed/locked and so will stop in middle of cycle. Please get back to me if you have any other questions.
Kevin
Posted on Jan 09, 2011
  • 6277 Answers
SOURCE: My Candy washing machine stops
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 12, 2011
Hi I have candy gcc590nb condenser dryer after a min or 2 it stops working and the start button flashs at a constant flash the clothes do heat up and the you can feel warm moisture
Check your belts and see if they are broken. Your blower may not be running. With no blower there will be no air flow there for not drying.
Jan 27, 2017 | Candy Dryers
I have a candy alise gow475, it starts up a cycle but stops whenever the drum should start to turn
motor speed sensor problem u cant fix yourself .it needs a skilled technitian.
Mar 30, 2015 | Candy Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Candy Alise-the stain blaster and 90 degree lights are flashing and it will not function. Please help!
Hi again,
11 flashes decodes as 'faulty dryer module or wiring to it'. Not sure that helps you other than saying that a service call is required, sorry ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
Candy GrandO 8kg Erratic Cycle Selection and Flashing Lights
I can't solve this problem but have exactly same problem with erratic lights. I 'm starting to worry about possible explosion.
Mar 12, 2010 | Candy Washing Machines
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Flashing lights on my candy washing machine
Hello Mikana, i have a brand new one and it also flashes the 90 and stain removel had the Candy eng out and it needs a new heater...all the electric goes throught this heater and if it detects a problem then it shuts down...the ones they fit at the company are not vrey good so the replacement is going to be better....ring Candy ........also if it has a large load capacity like 8kg don't under fill it it may send the drum of centre and this will stop the machine....self protection built in...hope this helps...cheers Dave
May 25, 2009 | Candy CNW156 Front Load Washer / Dryer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
