Question about Kitchen Ranges
I dont know how to adjust the burner jets on my frigidaire gas stove
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 55 Answers
I bought a new frigidaire gas range and the burners are sooting. How can i fix this
check that you are using the correct gas
there are different jet sizes between LPG and natural gas and the air shrouds have to be correctly adjusted
The gas fitter doing the installation would know this
Dec 10, 2017 | Frigidaire Kitchen Ranges
Can i convert a garland mod g286 stove from natural gas by installing apropane regulator
no
the modification from natural to propane or from propane to natural gas requires a jet change for all burners and an air flow shroud position change to get the correct blue flame ( correct air /fuel ratio)
it is a job for a gas fitter who will have the correct jets for each burner and will know how to adjust the shrouds
Jul 12, 2016 | Garland Kitchen Ranges
High flame on burner
the adustment screw should be at the valve.
Jun 14, 2013 | Frigidaire FGFB75D Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Flame goes out on front left burner when turned to low. Potentially filling the house with gas. Is there an adjustment?
Greetings from PNG. I have worked on many gas stoves because there are no experts here. The only screw type adjustments as such will usually only be on the oven control of which there are two adjustments. Apart from the regulator on the gas, there aren't any adjustments for the burners that I have come across. The most likely problem on any burner that does not perform is a blockage in the jet. If you are mechanically minded it is best to remove it to clean it properly but you could first try using a sewing needle or very small drill the same size as the jet to clean it out to see if that may fix it. Around the jet is an adjustment for air, which is usually just a circular metal flange that can be rotated to give a nice blue flame without any yellow. Try this first.
Jan 04, 2010 | Frigidaire FGF366E Gas Kitchen Range
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Gas stove burner problems
Just though of something after digging through a number of manuals on various sites--with our stove, we have to open the propane valve, let it sit for a bit--to let the pressure build I guess, before trying to light it. If we don't the burner never comes fully on. Still drives my wife nuts.
Oct 27, 2008 | CADAC Grilling
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
