Question about Corsair Memory Computers & Internet
Convert usb raw drive to fat drive
Raw drive convert to fat or ntfs
  • 27,725 Answers
The Fat32 (FAT) format is used to format disk drives on Windows-based computers and can also be recognized by the Mac's OS X operating system. You can format a flash drive with the FAT format so that it can be used on both PCs and Macs. The procedure is straightforward, if different depending upon the operating system being used to do the formatting. You do not need to purchase any additional software to format the Flash drive in the FAT format.
http://www.supermediastore.com/article/u/how-to-format-usb-flash-memory b> http://download.cnet.com/hp-usb-disk-storage/3000-2094_4-10974082.html
Format USB flash drives with FAT, FAT32, or NTFS partition types. Plug the Flash drive into a USB port on the Mac. Double-click the "Applications" folder inside of the Mac's hard drive. Scroll down to the "Utilities" folder. Double-click the "Utilities" folder. Scroll down to the Disk Utility program. Double-click on the Disk Utility program to launch it. Click once on the icon of the Flash drive that is in the left column of the Disk Utility program's main screen. Click on the "Erase" tab at the top of the window of the Disk Utility program's main screen. Name the Flash drive in the "Name" column at the center of the Disk Utility program's main screen. Select "MSDOS (FAT) from the "Format" menu beneath "Name." Click the "Erase" button at the lower right corner of the Disk Utility program's main screen. Click the "Erase" button in the pop-up confirmation window that appears. Wait as a progress bar at the bottom of the Disk Utility program's main screen fills in from left to right. Click the "Eject" button at the top of the Disk Utility program's main screen once the progress bar is completely filled in. Quit the Disk Utility program. Remove the Flash drive from the USB port of the Mac. b> Format Flash Drive in FAT on a PC b> Plug the Flash drive into a USB port on the PC. Go to "start," "My Computer." Right-click on the icon of the Flash drive in the center column of the window that appears below "Devices with Removable Storage." Select "Format" from the pop-up menu. Select "FAT32" from the "File System" drop-down menu in the window that appears. Click the "Start" button at the bottom of the window. Click the "OK" button in the confirmation pop-up window that appears. Wait as a progress bar fills in from left to right at the bottom of the window where you had selected "Fat32." Click the "OK" button on the "Format Complete" pop-up window when it appears. Right-click on the icon of the Flash drive that is on the desktop. Select "Erase" from the pop-up menu. Remove the Flash drive from the USB port of the PC. Hope this helps.
b>
Posted on Dec 23, 2012
How do i fix my usb flash drive .. it keeps going raw when i try to convert from fat32 to ntfs
When you say try to convert, you mean reformat from fat32 to NTFS? Depending on the size you may not be able to write it as a NTFS. Also, if you have anything on it you want to save, you need a raw recovery tool Squidoo has a good one.
However, if it won't let you format to anything and keeps reverting to raw, most likley your drive is damaged beyond normal repair.
Dec 29, 2014 | SanDisk Electronics - Others
Tip
How to convert FAT32 fmt to NTFS or vise verse...
Often we face problem while shifting data to USB drive or flash drive when the size of the data is big. It is because of the format of the USB or flash drive which is FAT 32. So here goes the way out to convert FAT 32 into NTFS-
How to convert a FAT volume or a FAT32 volume to NTFS
    1.In search of windows 7 or 8 type cmd.
    2.In command prompt write-
    chkdsk j: /f
    3.Then type-
    Convert J: /FS:NTFS
    *REMEMBER HERE J MEANS THE DRIVE LETTER.
on Apr 13, 2015 | Computers & Internet
How am unlock sandisk password. SDCZ40-032G-E11
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
hope this helps
May 09, 2011 | SanDisk DRIVE,USB,32GB,ULTRA,BK -...
I want to convert USB Sticks in RAW to FAT 32 (they were received faulty, they shoulf hasve been fat 32 but were received in raw)
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format USB Stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 24, 2010 | Electronics - Others
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to convert RAW to FAT, FAT32
I'm facing big problem. Hdd was in RAW format and I want to convert in fat32.
Apr 12, 2009 | Computers & Internet
RAW FS TO FAT 32
i recently bought a sony flash drive SSK/2GB.however the same is not working at all as it is showing RAW file system instead of FAT 32 .neither it is getting formatted nor allowing anything else to b doneto it.
Nov 11, 2007 | Electronics - Others
Computers & Internet Logo
173 people viewed this question
Top Corsair Memory Computers & Internet Experts
David Payne
David Payne
Are you a Corsair Memory Computer and Internet Expert? Answer questions, earn points and help others
