Vent Vaccum hoses on '03 Windstar
Hey michigan man. Thanks for the advice on checking the vent vaccum hoses. The hoses looked okay behind the control unit. I then followed 1 orange and 1 black hose going behind the glove compartment and then I think they go to the engine area. I looked under the hood and found a vaccum line with a T splitter. 1 red hose went to the engine area. 1 black went to the inside of the van. The 3rd opening was open. Is that orange hose suppose to connect to that or does it go somewhere else? If it is suppose to, then how do I get it to the engine area? I tried to see of the orange one was loose on the inside, but it didn't really pull back at all. Do you have any ideas? Thanks in advance.
yorte21
(p.s. sorry for the wrong category thing....it wouldn't let me choose past Ford)
    Brigadier General:
  • 3,533 Answers
Go to auto zone and they have quick connect tubing (like a little adapter) and they will help you out Good Luck glad to be of assist
michigan man
Posted on Jan 12, 2009
Heater control doesnt turn 'vent' off? need tech insight.
need car type and year but there are to trypes of selector switch elec and vaccum. the solinoid at the vent system either electric or vaccum operated is brobably bad
Feb 26, 2013 | Cars & Trucks
My ac quit blowing through the vents and only comes out the defroster vent. could it be bad vacume hose? if yes where is it located? so i could replace it. thanks
there is a vaccum hose coming from the intake manifold behind the a/c compressor goint to the vaccum tank right hand of the radiator the main hose will split by the thermostate housing center front of engine, you will need to repair the hose and or repl hose that should fix ya up
Aug 10, 2010 | 1998 GMC Safari
Our 1998 buick lasabre air condioning will not blow out vents. everything works, but it wont blow out vents. it will blow on window vent and blows on floor vent.but the middle vents will not blow out.
ck to see if your vaccum hose if broken at the engine vaccum connection, it may have a vaccum hose split or a bad vaccum switch/actuator, if it has manual a/c, if it has electronic a/c then your mode actuator is not working.
Aug 10, 2010 | 1998 Buick LeSabre
Blower switches from vent to defrost when accelerating
should have a vaccum check valve somewhere losing vaccum on accel may have a cracked resevoir or something
Jul 16, 2010 | 2003 Ford Windstar
Air stopped coming out of teh face vent
you have a blend air door problem. if the control head is working properly then you should look behind the glove compartment for loose vaccum lines or wires.
Apr 29, 2010 | 2000 Nissan Altima
No air is coming out of my top vents but air comes out of my bottom vents in my nissan sentra
check all of the vaccum lines and the control unit itself give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man.
Mar 04, 2010 | 2006 Nissan Sentra
VENT FOR AIR CONDITIONING NOT OPENING
check the vaccum lines under hood and also make sure they are not off behind the control unit itself try these website to see if you can get any more information car A/C repair www.directgardening.com fix & troubleshoot heating & A/C www.automedia.com i also would like to give you this information if you every have any hard to find GM- parts only its Schram auto & Truck parts 1-800-292-1032 and they website is www.schramauto.com best of luck Michigan Man.
Jul 30, 2009 | 1997 Pontiac Bonneville
Switch will not change from defogger to other vents. What are possible problems and solutions
Sounds like the blower motor actuator which is vacuum driven. You most likely have a vacuum leak, preventing the actuator from switching from defrost to vent. Check under the hood and start at the firewall (usually on the passenger side) and with the blower on high, look for a possible vacuum leak. Best of luck.
Greg
Jun 25, 2009 | 1997 Chevrolet Astro
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
