Question about Acer Aspire One AOD2501604 Netbook
How to wire the back up lights on a 1988 camaro iroc z from the shifter on
When i bought my camaro the back up lights were cut at the shifter, I know the light green wires come from the lights to the shifter but I dont know what to do from the shifter on.
  • Acer Master
  • 7,627 Answers
Wrong category
Posted on Dec 07, 2012
Where is the horn relay located on a 1988 camaro?
I believe it is plugged into interior fuse box.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20080504172413AA78RKW
Fuse box diagram for 1988 Camaro Iroc
1988 camaro fuse box location Google Search
Mar 19, 2016 | Cars & Trucks
How do i replace the rear axel bearings on a 1988 Chevrolet IROC Z28 Camaro
Put car in neutral, remove wheels, calipers and rotors, diff. cover. rotate carrier until you see wrist pin retaining bolt, remove bolt and slide out the wrist pin out of carrier. Next push axle inward to remove inner axle "C" retainer washer then slide axle out of tube. Then pry off axle seal and with slide hammer w/attachment remove axle bearing.
Feb 23, 2014 | 1988 Chevrolet Camaro
I have a 1988 iroc 305 tpi 5spd car runs fine till it gets hot. I have replaced pulgs,fuel pump,fuel filter,cap,rotor,wires,3 sensors.
might wanna check the fuel injectors when the start going bad they get a high resistance at engine normal temp
Jun 15, 2011 | 1988 Chevrolet Camaro
1988 camaro iroc z 350 tune port injected. need to reset timing on the computer. jodie
To set the ignition timing you will need to disconnect the electronic timing control. It is usually a dark brown and black wire located on the passenger side foot well where the carpet meets the firewall. Once the wire is disconnected, loosen the distributor and set the timing with a timing light. If you have an automatic transmission, I think the timing is 6deg BTDC. Tighten the distributor down and connect the ETC wire.
Mar 12, 2011 | 1988 Chevrolet Camaro
Just bought a 1987 Iroc Z. Need to know why my
look at waser bottle and there is a pump . replace the pump very easy to do
Nov 12, 2009 | 1987 Chevrolet Camaro
Do you have a spark plug wiring diagram for a 1988 camaro iroc z 305 tpi
Okay, #1 is marked on the distributor so in clockwise order: 1-8-4-3-6-5-7-2
8 7
6 5
4 3
2 1
(Front)
Hope this helps,
matt
Oct 07, 2009 | 1988 Chevrolet Camaro
Starter on a 1988 camaro iroc z
go to your local auto zone or advance and get a manual and look it up!! hell jus go in with a friend and pick da book up and jus walk around like your looking and read up on it!! I would have to check others but im sure i people that know!! Let me know if you are unable to do this!
Sep 27, 2008 | 1988 Chevrolet Camaro
88 iroc camaro
Check the fuses under the dash drivers side.Also check the fuses/relays under the hood on the left side in a black plastic box.
Jun 26, 2008 | 1988 Chevrolet Camaro
Acer Aspire One AOD2501604 Netbook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
