Question about Onkyo TX-SR307 A/V Receiver
Receiver: Teac AG-D9320 . press power, muting light blinks about 6 times then goes into standby
Teac AG-D9320 A/V 5ch. This was disconnected in march 2011 and today I hooked up again . (almost 2 years) When I pressed power, the standby light comes on. It is holding there. so now I press power again and the muting light blinks about 6 times then it goes off including the standby light. It is not coming on at all. Is there someone who can advise me on this problem/ Thank you ever so much . sonibedasie@yahoo.com
simplemitch
  • 752 Answers
SOURCE: power works but receiver will not stay on
The outputs are blown and will require repair.
Posted on Dec 18, 2007
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
petraman7
  • 1175 Answers
SOURCE: blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Posted on Jan 14, 2009
Gurudristi
  • 98 Answers
SOURCE: The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Posted on Mar 13, 2009
  • 4234 Answers
SOURCE: receiver keeps turning on and off also the standby mode blinks
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Posted on Oct 15, 2009
Why does my Teac receiver only light up the volume, then shut back off?
Your receiver has developed an internal short circuit and the unit is shutting down to prevent further damage. You might want to check the power supply for problems since it is a hard working area and prone to failure.
Sep 01, 2015 | Teac AG-V8060 Receiver
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
NEED MANUAL FOR TEAC-AG 9320
use a search engine (I used Google)
"Teac AG-D9320 manual"
retrevo.com has the link
Aug 11, 2011 | Teac AG-D9320 Receiver
TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Aug 08, 2011 | Teac Audio Players & Recorders
How do you reset the blinking protect banner on the ag-v8520?
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
Jun 13, 2009 | Teac AG-V8060 Receiver
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Teac AGD 9100 user guide
Click on your brand name Teac (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line. And dont forget to rate me, on this great site.
Dec 25, 2007 | Teac AG-D9320 Receiver
Teac ag-d9320 5.1 receiver fuse
Make sure the fuse you put in matches the power requirement of the device you're installing the fuse into, putting a fuse that does not handle the current will cause this, but do not overshoot as this may fry your device - it must match. If you know it's matched, then the device you're installing the fuse into may be faulty in such a way that it is drawing the wrong amount of power. This can be due to the power supply on the unit.
Sep 07, 2007 | Teac AG-D9320 Receiver
Teac AG-D8900 Receiver - No power
Hello meml,
Since you mention that there is no standby light at all, the problem could be related to the receiver's main power supply, which is not uncommon for a unit of this age.
Now, if you decide to take the unit to a repair shop, do not let the cost of repairing the unit be the only factor that determines if you bring it back to life or to use it as a door stop.
Consider the replacement cost compared to the repair cost, also, have in mind that newer receivers can supply more output power per channel and have more advanced decoding technologies among other features. Hope this helps your decision. Let me know.
cancerags.
Apr 11, 2007 | Teac AG-D8900 Receiver
Onkyo TX-SR307 A/V Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
