Question about GPS Navigation System 2005 Mercedes Benz CLK320
I need updated GPS disc for 2005 Mercedes clk 320 convertible
You can go to http://www.repair-service-manual.com/search?q=gps.
You can choose your vehicle and update your gps.
They have wonderful deals . The DVD works well and it comes with a very affordable price.
Hope this helps.
Posted on Mar 02, 2013
Where is the window relay located;
Check the fuses. The relays will be in the fuse box as well. The legend should be on the lid. Check the one in the car and the one under the hood.
http://mbworld.org/forums/attachments/clk-class-w208/57664d1123115668-fuse-box-under-hood-help-fusebox.jpg
Check out a couple of these videos.
http://www.bing.com/videos/search?q=2005+Mercedes-Benz+CLK+320+replace+window+relay&FORM=HDRSC3
Mar 16, 2016 | 2005 Mercedes-Benz CLK 320
Set clock for mercedes clk 320
go to setting and choose clock setting, pushing the button up and down until the correct time, then the clock will turn automatically to match the digital clock you set in the setting.
Apr 18, 2013 | 2005 Mercedes-Benz CLK 320
Can you assist with where the power steering resorvoir is, need to add fluid to a 2005 clk 320
On the drivers side of the engine you will see the oil filter housing and an air tube. The power steering reservoir is under the air tube.
Apr 09, 2013 | 2005 Mercedes-Benz CLK 320
Where is the fuse for the low beam for a 2005 clk 320
there should have a fuse layout or description in the fuse compartment near or under the light switch.
Mar 29, 2013 | 2005 Mercedes-Benz CLK 320
The Convertible top of Mercedes-Benz 2005 CLK 320 won't open or close.
If the "black part" you are talking about is the "trunk partition"(which should come up as a "fault" on the dash when you try and cycle the top) then there are several things to check. The partition itself should snap into the retracted position(forward), and back. If it doesn't there are two struts(also called air springs) that have lost their charge and are not holding the partition in place. It has to be held solidly in place to set the switch on the left side(driver side) in order for the top to go down. If it's at all floppy, it won't set that switch and the top won't cycle. I've found the hard way this is a common problem.
Mar 18, 2013 | 2005 Mercedes-Benz CLK 320
320 clk mercedes fuse blows for central locking as soon fitted
There a shot this can be rub through wire or its power touching ground, The power goes into the door control module form there it reaches the door lock actuator, disconnect door lock actuator,if the short stop repair the actuator,if it does nt move to the driver door lock module disconnect that if the short stop its in the module if it doesnt its in the wire
Mar 13, 2012 | 2005 Mercedes-Benz CLK 320
Mercedes Benz CLK 320 1998 Radio Code
try asking here
www.ukbookshelf.co.uk
May 30, 2010 | 1998 Mercedes-Benz CLK
Need to find battery location: 1999 Mercedes CLK 320
Hi, The battery is located in the trunk, under the trunk mat.
Apr 08, 2009 | 1999 Mercedes-Benz CLK
GPS Navigation System 2005 Mercedes Benz CLK320 Logo
183 people viewed this question
Top GPS Navigation System GPS Experts
Are you a GPS Navigation System GPS Expert? Answer questions, earn points and help others
