Question about Apex Digital GT2715 27" TV
Apex Gt2715 wont turn on
Wont turn on, tried different electrical outlets nothing worked
    Genius:
  • Apex Digital Master
  • 2,432 Answers
That was mean their is a problem either in the power supply section or at the main board. which need a proper trouble shooting and repair. which can be hand held by a trained tv repairman. just let me know if you will be the one to do the repair so i can give further solution.
Posted on Dec 07, 2012
2 Suggested Answers
gopakumarg43
  • 74243 Answers
SOURCE: how do i reset an apex tv set with model number
Hello
You are locked out I thinks. Try the following to override the locking.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Posted on Dec 02, 2010
My apex digital tv turned off and wont come back on. what do i do?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 13, 2015 | Apex Digital Televison & Video
Need codes for remote model number uk1a if it will work for converter box digical stream model number dtx9950
Your remote is only able to control TVs and DVD players. It will not control your DTV Converter Box.
Here is the remote (Apex UK1A) manual:
http://remotes.com/remotes/documents/Apex/UK1A.pdf
Here is your DTV Converter Box (Digital Stream DTX9950) manual:
http://cbsdallas.files.wordpress.com/2011/01/radio-shack-digitalstream-dtx9950.pdf
Jan 06, 2014 | Apex Digital GT2715 27" TV
Apex LE2414 won't stay on
It is likely that there is a problem with the internal power supply.
Dec 31, 2013 | Apex Digital Apex 24 in. LED 1080P 60Hz...
How do i reset an apex tv set with model number gt2715?
Hello
OK.
Dec 02, 2010 | Apex Digital GT2715 27" TV
The red lock button is in the bottom left corner of my GT2711S tv how do i get it unlocked
check your remote for a simular looking button with the lock symbol by it.
Oct 24, 2009 | Apex Digital GT2715 27" TV
Apex GT2715 TV, burned resistor
Wire wound 190 ohm 10 watt should do the trick if that's all that's wrong with the set...accordianman
Feb 02, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Delonghi TRD0715T Safe Heat Oil-Filled Radiator will not work, won't turn on its new just taken out of the box
Ditto same problem. Took it out of the box, plugged it in the electric outlet and did not turn on.
I tried atleast 5 different electric outlets to make sure nothing is wrong with the outlet. Tried changing the timer settings. No use.
Returned it to Lowe's.
Nov 17, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Apex Digital GT2715 27" TV Logo
54 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
