Question about D-Link DIR-600 Router
Very slow wifi connection from router dlink dir-600
When i connect wifi devices to the router Dir-600, the connection was setup and i am able to see the link but there is no connection to the webpages . its says connection lost or very slow. It was happening often and often. I tried to reset the router but still the problem exits. Where as the LAN connection was good.
    Novelist:
    Habit-Forming:
  • D-Link Expert
  • 199 Answers
I had this issue also. If rebooting the router does not improve or trying a new cable between your router and internet modem, you will have to do a factory reset. You can do this by logging into the router and selecting factory reset by locating a small hole on the back of your router, insert the tip of a paper clip for about 10 seconds with he power on, and this will reset your router to factory settings and of course you will have to set-up everything from scratch.
Maybe do a firmware update at the same time.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Posted on Jan 06, 2017
4 Suggested Answers
beeveez
  • 167 Answers
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Posted on Mar 08, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
SOURCE: wifi problem of DIR-300 dlink
Hi all,
Good day,
I have purchased a DIR-300 Dlink router. the connection is OK via LAN. the issue is the wifi I cant receive IP from the DHCP server of the router.
Kindly assist.
Qureshi
Posted on Jan 22, 2010
Why my d link dir 600 has no wifi signal
What is colors of lights in your dlink box
skype id : johnwalker800969@gmail.com
May 07, 2014 | D-Link DIR-600L Wireless N 150 Home Cloud...
Authentication problem on android ipad
You will get an 'authentication' problem trying to connect to this dlink 600 or any other wifi services/routers that are 'protected' and encrypted using WEP or WPA or WPA2 security (e.g. not public or 'OPEN' network): apart from the SSID, you will need to set your android tablet or ipad to use the WEP or WPA or WPA2 PASSWORD/PASS KEY to successfully connect (you get it from the Wifi/Router administrator).
Apr 06, 2014 | D-Link DIR-600 Router
Please help!
What are possible reasons that only power LED is on?
1) LAN & Internet cables are not connected to powered devices. Check cables and devices connected to D-Link ports.
2) Power supply failure. Try to replace AC adapter.
3) SW error. Try to reset deivce to factory default by reset button. It is placed on rear panel in small hole.
Manual is available here:
http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20600/Manual/DIR_600_B_2_Manual_EN_UK.pdf
Nov 19, 2013 | D-Link DIR-600 Router
I recently bought and through fixya.com I managed to connect a D-link DIR 600 router to a network of my apartment. We use hotspot login for this network because its not only me to connect. The problem
Hello here you can download info:
http://www.dlink.com/us/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Youtube setup:
http://www.youtube.com/watch?v=YzV3k845TJ8
Here is a picture how to connect it:
Connect the cable from your internet provider to the internet port.
The blue ports or 1 - 4 is for non wlan connections
such as a desktop pc or a network printer.
You maybe have to setup the wireless network with a code
so others can`t use your internet.
Good luck
Nov 19, 2012 | Computers & Internet
Can't connect XBOX 360 S to D-Link DIR-600 Router
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Mar 04, 2012 | D-Link DIR-600 Router
Please help.... I have just purchased a dlink dir-600 wireless router and I can not connect to 192.168.0.1 from my mac.
For setup, you need an Ethernet cable connection to the router, WLAN needs to be configured first before you can use it to administrate the router.
Quick installation guide is here: ftp://ftp.dlink.de/dir/dir-600/documentation/DIR-600_revb_qig_multi.pdf
The default user name is "admin" with empty password.
If you suspect the settings are not at factory defaults, press the reset button at the rear for 20 seconds with the router powered on.
Feb 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-600 Router Logo
844 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
