Question about Nokia N86 Smartphone
My nokia n 86 is not getting switched on after charging it overnight. What can be done to it to switch it on?
I had put my mobile in charging at 10.30pm and took it off the next morno=ing 4.30 am. When i looked it into the mobile it was switched off, and its not getting switched on.
    Master:
  • 368 Answers
First Option:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Second option:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
Posted on Dec 07, 2012
micromaster
  • 3614 Answers
SOURCE: Nokia 6300 -Wont switch on , only has blue lights
your cp having a defective lcd now. it need to be replace and send it to repair center,
Posted on Nov 05, 2008
SOURCE: My nokia 5610 is displaying local mode but then not switching on!
download and install NSS (Nemesis service suite) here is the link.
http://www.b-phreaks.co.uk/index.php?main_page=page_2
1. click the manifying icon on the top right
2. click PHONE INFO
3. click SCAN (it should be in the middle)
4. and then in the power box. you will see 3 option (local, test, normal)
5. check NORMAL and click on change
6. now your phone turn on by itself..
7. GOODLUCK!..
Posted on Dec 28, 2008
SOURCE: NOKIA 5310 can't turn on
Okay, so I totally freaked when this happened to me :(
BUT! I think I figured out how to fix it :)
As mentioned by others, remove the parts and put them back in.
1. Remove the Battery
2. Remove the Sim Card (You can't remove without the battery first taken out [SO DON'T TRY :P])
3. Remove the SD Memory Card
Now... I put them all back in and powered it back up... and it did the white/black screens :(
So then I tried again, several times, to no avail.
What worked for me is, when putting them back in, ***do not insert the SD Memory Card***
Power it up with just the battery and Sim Card, and see if it works. For me it did. I think something in the memory was corrupted... :(
I've since tried powering the phone off, putting the SD Card back in, and turning it on... it still loads now, but it isn't registering the memory :(
So, as a lesson, back up your data early and often. Which I luckily did :) And now I think I have an excuse to upgrade to a bit larger memory :P
Hope this helps!!!
~OkamiShonen
Posted on Feb 01, 2009
jonniewalker
  • 1029 Answers
SOURCE: tell me how to reset nokia 6708
Try this reset procedures
Normal Reset (*#7780#) : Restores ini files from rom but preserves user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : This re formats completely the C: drive. All applications and files stored on this drive will be lost and clean default files will be rewritten.
--- WARNING: This will ERASE EVERYTHING on your phone ---
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the your phone.
Do not let go the three keys until you see the "formatting" screen displayed
5. After a few minutes, the format will be complete. Your phone
will now be at its original factory settings.
Posted on Oct 08, 2009
  • 7 Answers
SOURCE: My nokia 5310, won't charge. I plug it into the
My Nokia 5310 also wouldn't charge; pocket lint had become trapped in the charging hole, and was packed down over time. I used a very thin straight-pin to gently scrape the lint out of the hole until I could see the gold-colored metal pad at the bottom (using a very bright flashlight and small dental mirror to direct the light). That took about 20 minutes. Now the charger plug slides all the way into the port and clicks into place. Tip: Be gentle, that center pin will break if you try to use something fat, like a safety-pin or a toothpick. -- John Dollison, Colorado.
Posted on Dec 28, 2010
Nokia 3110c switching off
It may be the battery or the memory card or its os. Check your battery, does it has sufficient charge to switch on the mobile, is it holding charge after charge, if not then replace it. Try to switch on your mobile without using your memory card and if it is successful then scan for virus or replace it with a new one. If the above things does not works then visit Nokia service centre for flashing your phone with a updated software.
Jan 16, 2014 | Cell Phones
Hai sir my mobile model is nokia e52 suddenly it has swithed offed.. but when iam swithcing on the mobile it is not swithing on.. but how to collect my important contacts n data... without switching on......
You need to leave it charging for many hours say overnight.
After that to switch on, you must hold the power button a few sec. until it stays on.
Dec 24, 2013 | Cell Phones
My NOKIA 3110c phone got switched off by itself and has not come alive. If I try to switch it on, the screen blinks white thrice and then goes dead again!
Firstly, Remove Sim Card , Memory Card and try to reboot 3-6 times,sometimes this trick is working.Even if the problem still persist better to contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
1time my mobile battery is low and my mobile is switch off and then i put charge and i switch on my mobile and my mobile ask the security code i put the default code 12345 but the code error so pls send a...
Hello Rsrirm,
Switch off the phone.
Remove the battery for 30 minutes.
Reinsert the battery and switch on the phone.
Enter the default code 12345.
Your phone will be unlocked
Apr 10, 2011 | Nokia 2690 Cell Phone
ON putting my Bluetooth hands free Nokia BH 101 only the red light goes on blinking. I have put it on charge overnight still i cant switch it on. How should i fix this ?
SO!! FINALLY! Connect headset to the charger. Wait for 1-2 mins, then HOLD VOLUME UP key + SWITCH ON KEY for.. donno i waited for 30 sec, then looked at redlight and suddenly saw a GREEN LIGHT lightning, but it's so hard to see it. I'll try to do a photo.
Dec 18, 2010 | Nokia BH-104 Bluetooth Headset
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
White screen
This is the problem with corrupted phone software you need to reinstall the phone software get it done by the company if it still under warranty or if its out of warranty get it done in local mobile service center..
Good luck..
Aug 19, 2008 | Nokia 7373 Cellular Phone
Nokia N86 Smartphone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
