Question about Philips Magnavox 42MF521D/37 Television
Magnavox flat screen tv has lines on one side of the picture
Any suggestions?
    Top Expert:
  • Philips Master
  • 14,553 Answers
If its production date is more than four years retire it, to answer your question the set will have two single or one large boards, the two board version one of the boards drives the picture on one side of screen and other on the other side, the version with just one larger board combines both boards into one
You might want to Google the model number with"parts" to see what is available and at what cost for this set, They only sell boards and no individual parts for all of this type of set.
Posted on Dec 07, 2012
5 Suggested Answers
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
rootbeer001
  • 352 Answers
SOURCE: Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Posted on Jul 14, 2010
SOURCE: I have a 42in Magnavox flat screen. When my TV is
I had something similar shortly after I bought mine, my 11 year old walked over to the set and used the on-board power button, telling me everytime we lost power he has turned it on there before the remote could do it. At least it is worth a try....
Posted on Aug 13, 2010
  • 608 Answers
SOURCE: Magnavox 42" flat screen clicks
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
Posted on Dec 13, 2010
I have a Magnavox 65" Tv with 2 large vertical lines on screen. Is it the T-con board thats bad?
T con board is responsible for picture image and aberrations are usually caused by an issue with that board.
Dec 23, 2016 | Magnavox Televison & Video
My magnavox model# 42mf230a/37 tv turns on I get good sound and picture but it has a 4inc black line onleft side edge of screen
Black lines on Plasma TV are cause by either the buffer boards or the logic board. OR your screen is bad. the only way to find out is the replace the boards. I would start with the Buffer boards. The buffer boards are located on the bottom of the screen attached by ribbon cables to the screen. look at the bar and replace the board that lines up with it. You can find parts fro this TV at www.interliquidparts.com You have to get the actual part number from the part on your TV to get the correct one.
Jun 13, 2011 | Televison & Video
Picture Size
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Troubleshooting magnavox television model 20mt1331-17
I have a model 20tm1331-17 magnavox tv and when i go to turn it on it will turn itself back off. Any suggestions as to the problem?
Sep 27, 2009 | AOMNI Corporation Magnavox 20MF500T/17 20...
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
May 13, 2009 | LG 50PX4DR 50 in. Plasma TV
Blue Screen with thin horizontal white lines
THI IS THE INTERNAL CIRCUTRY FAULT BEST YOU
call the service person and dont try to open it other than in side of TV SET HAVING Hazard of electrical shock be handle most care fully .
and check video board and all.
Oct 19, 2008 | Philips Magnavox 20MS233S 20" TV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Philips Magnavox 42MF521D/37 Television Logo
282 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
