Rank: Apprentice
Rating: 83%, 18 votes
If you have a shortcut on your desktop you can do the following:
- Right-click on the FM shortcut.
- Choose "Properties" from the pop-up menu.
- In the "Target" field, add the --reset_preferences command line option after "fm.exe", so it should look like this:
"C:\Program Files\Sports Interactive\Football Manager 2009\fm.exe" --reset_preferences
- Press OK and then try to run the game as normal, using the shortcut.
You'll want to remove the command after you run the game, as otherwise
it will continue to reset your preferences every time you launch.
If you don't have a shortcut you can make one and then perform the instructions on the shortcut you've made.
