Question about Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
Gost image and a vertical line in the middle of screen.
  • Sony Master
  • 933 Answers
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Posted on Dec 07, 2012
4 Suggested Answers
SOURCE: Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Posted on Oct 08, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
leusnerdus
  • 54 Answers
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
Posted on Apr 20, 2010
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
The image on the TV has sort of condensed and disappeared. Now there is a bright line across the middle of the screen and a sliver of (about an inch) of image above that line. The rest of the screen is...
You have a vertical output IC that needs repaired. You may need to only resolder the vertical output IC. If then you do resolder, you will need to check and replace any capacitor in the immediate area of the vertical IC. A weak or bad capacitor will heat up the IC, and create rings on the pins under the IC. Also check the solder grounds on any resistor and diode that are immediately near this IC. This will bring your TV back to full view. Thanks for asking and show a few hands of support!
Oct 04, 2010 | Hitachi 36UX01S 36" TV
Two white gost lines in the middle on the middle of the page ( one two millimeters wide) , the other 2cm away and one ml wide with shadows There are several other with similar distance from eacjh other but...
Something is wrong with your printer -- part of the drum is *NOT* holding the magnetic-charge that the laser should be creating. So, none of the ink "sticks" to the paper, resulting in a WHITE strip.
Take the printer to a qualified technician, for proper trouble-shooting & repair.
Apr 05, 2010 | Konica Minolta magicolor 2400 Laser...
TV not working properly
You have a vertical problem. See if there are any vertical (height or linearity) controls to adjust. Often there will be screws or knobs on the back.
Otherwise, it could be bad transistor or component in the vertical-deflection circuitry.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Sony BRAVIA KLV-37U300A 37 in. LCD TV Logo
451 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
