Question about Tools & Hardware - Others
I have a Dewalt 625e type 2 router which just quit working. I replaced the switch and the PC board but it still doesn't run.
  • 885 Answers
Check both brushes. Some DeWalt brushes have a spring loaded plastic pin built into them so when it wears down the pin pops out and prevents damage to the armature. Other brushes have a copper wire that, when the brush wears to a certan point, it will no longer touch the armature again preventing damage to the armature.
Posted on Dec 19, 2012
Changining my wifi passphrase
connect your pc to the router with ethernet cable.
open web browser and in the address bar type 192.168.1.1 (if this doesn't work try 192.168.1.2)
you should get your router's home page.
when asked for user and password type admin for both.
if that doesn't work try admin and password
go through settings to where the password is and change it.
save the changes and you're done.
Oct 31, 2012 | Cisco Computers & Internet
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
Is their a repair for a bad switch ?
You can try spraying the switch with electronics cleaner and blow it out well with air. If that doesn't improve the performance of the switch the only fix is to replace it, there are no replaceable parts in the switch. You can go to http://www.ereplacementparts.com/ and search for your model to find out what switch you need. Parts are available there or you can use the part number to search the web for better prices, Dewalt switches are not cheap.
Jan 15, 2012 | Dewalt Drills
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a Bosch SHE4AM15UC Dishwasher that short cycles. After about 2 minutes it quits and the clean light comes on. The unit doesn't fill with water and the soap dispenser does not open when this...
they will send out an engineer not supply you the part while still under warranty if you fit parts under warranty you will in validate it get the engineer out.
Mar 03, 2017 | Bosch SHX65P05UC Dishwasher
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
I have a dewalt 2 1/4 hp type 1 var speed soft start the magnetic ring broke had it replaced by a dealer still doesnt work i replaced the speed module still nothing sometimes it wants to run it might...
could be brushes stuck, the tubes might have been smashed a little not allowing them to contact the armature or other major electrical problems, Check for continuity thru the brush tubes and see what you get.
Mar 09, 2009 | Dewalt DW618 Router
Tools & Hardware - Others Logo
199 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
