Question about Mitsubishi HC900 Multimedia Projector
Lamp turns off
Can anyone give me an idea as to what might be wrong? I can use my projector for about 5 mins, then the lamp suddenly turns off. When this happens, the power light is red and the status light flashes green. Do I need a new lamp? or what? I can still here the coolng fan running.
  • cutrone10 Jan 06, 2009
    I have the same problem. Has anyone fixed this by hand on the HC900
The solution is a weird one. I had the same problem with my Sony Cienza VPL-HS1. Run for about 5 minutes and then the lamp would go out. The warning would show that Lamp/Cover was an issue. I assumed the lamp had reached its lifespan.
Wrong.
All it was, was the filter sitting in the filter box has a small trigger switch that turns off the lamp as a safety when someone inadvertently opens the cover for the filter.
Well, strangely enough, the box and the cover are sized in a way to expand when they heat up. (which they do aggressively) When they heat up they expand, and ever so slightly move the filter away from the switch far enough to trigger it to the off position (only about 1/64th of an inch).
Thats why when some of you tip your projector on its side it runs ok (gravity pushing the filter back in place).
The solution is to put a tiny strip of duct tape along the far edge (the edge opposite of the switch) of the filter on its plastic surround. This will snug-up the filter harder against the switch. Even when it tries to shift under expansion and contraction, it will not allow the switch to poke out far enough to turn off.
So, a penny of tape does the job!
JC Dallas Texas
Posted on Dec 22, 2007
Funny, mine is mounted upsidedown and does the same as yours. After it starts up, it woks for about a minute or two and shuts down.
When I turn the unit on its side(yes sideways) it stays on and does not turn off! WEIRD!
I can only come to the conclusion that it has some kind of loose connection or something.
Randy Fletcher
Laveen, AZ
Posted on Oct 14, 2007
What is wrong with Acer P7280 projector? The lamp goes out after 10 min. use, and red lamp error led turn on
the lamp must be ok
the ballast may be fault
or the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jun 18, 2014 | Acer P7280 OEM Projector Lamp
Acer p7280 projector lamp goes out after 10 min., and red error lamp light up.
The lamp must be ok
Have a nice day!
Lampdeng Limited
Jerry
Suddenly power off
check the lamp please,
to replace it with a new lamp,to check it
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 13, 2014 | Sony VPL-ES7 LCD Projector
I have a sony and it uses the KDF-E60.i turned the tv on then after like 5 min. the tv turned blank and the sound turned off and a while after the screen came back on and then the sound came back on.i ask...
so this is a projector , if the unit is turning off and giving led signal error like green flashing, your bulb needs a replacement. its a warning that it has nearly end of his lamp life. dust and poor ventilation can shorten the lamp life. its a good idea to clean the blower and ventilation inside the projector.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Projector turns off after about 30 minutes. What's wrong?
your projector status means the protection circuit is working or the lamp is in an abnormal condition.
--wait until status indicator goes out and press power button.
---if the above solution is not working change the lamp.
Nov 19, 2006 | Mitsubishi HC900U Multimedia Projector
Projector turns off after about 30 minutes? What's wrong.
Check to be sure the safety switch at the filter is not being tripped when the case and or the filter surround gets hot and expands. Thats what mine did.
Nov 19, 2006 | Mitsubishi HC900 Multimedia Projector
Mitsubishi HC900 Multimedia Projector Logo
562 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
