Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Injectors won't inject on 1995 Chevy Silverado
    Scholar:
  • 117 Answers
Check for a bad ignition fuse, ign module, or computer connections or computer.
Posted on Nov 02, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: fuel injectors location for a 1995 chevy camaro
that year uses a throttle body injector, which is located underneath the air cleaner. take the cover off and then take the housing for the air filter off. its right there
Posted on Jun 19, 2009
1994 chevy s10 pickup 4.3 L throttle body injection won't start and dies at idle...
So my first question is - have you checked fuel pressure at the injectors ?
Apr 06, 2013 | Cars & Trucks
95 chevy pick up 5,7L . have spark, have fuel, won't start?
how much feul pressure, it must maintain a certain amount if injected, or throtle body, try priming it ,and see if it helps, ( poor a little into inlet ) and check it , if it starts you need to check pump, or maybe just filter
Nov 17, 2012 | 1995 Chevrolet Suburban
My 2001 Chevy 2500 HD 6.6 L turbo diesel won't
fuel injection pump is failin or has issues--getta haynes manual for pro car maintenance
May 30, 2012 | 2001 Chevrolet Silverado 2500HD
2002 chevy silverado won't start, replaced fuel pump, still won't start
Same problem here, found break in wiring harness at cross-member behind cab. did have bed removed for easy access. Ground wire guilty party.
Dec 18, 2011 | 2002 Chevrolet Silverado
Chevy silverado 1500 305 engine would not start. Replaced starter & starter would not disengage
smaller of the 2 wires is on the wrong terminal,or the starter needs a shim to move it away from the ring gear,if it is too close it won't come out.
Oct 07, 2011 | 1999 Chevrolet Silverado 1500
I need diagram to install spider fuel injector assembl for chevy vortec engine
Just put chevy fuel pressure regulator & spyder assy in your search engine
You willl have hours of reading etc
Removing the intake will be a lot of work
Installing the press reg & spyder won't take long or need
instructions.
Sep 27, 2011 | Cars & Trucks
Chevy truck year 1998 silverado 1500 350 engine what sensor is it that lets the gas get to the carborator i change the ignition mar under the distbor cap put a new gas filter check the fuses. i check my...
i'm pretty sure you have a Central Port Injection setup on this engine. Which means the injectors are inside of the upper plenum and cannot be seen. This type of fuel injection system uses a centrally located electric fuel injector(s) which feed fuel to a mechanical poppet style injector which is routed directly above the intake valves for each cylinder.
The poppet valves require a minimum of 56 psi of fuel pressure. If you have 55 psi it will not start. It needs the fuel pressure to overcome the mechanical resistance of the poppet injectors. Fuel pressure should at least be 60 psi. It is very important to check fuel pressure with an accurate gauge.
If fuel pressure is low it will not start no matter what you do and a new fuel pump will likley fix the problem. Get a good quality pump such as an a/c deco or Dephi. Other brands may be cheaper but they will not last.
If fuel pressure checks out good let me know and I'll give you some more info.
Jun 29, 2011 | 1999 Chevrolet Silverado 1500
1995 chevy silverado wont start unless primed will not start on its own new pump new sensers new filter have its throttle body injected i tested injectors no power to them while turning over but if you...
look at your igniton module. is there a colored spot of paint on it? if so you need to replace it. they over heat and the black paint turns a color. common problem if you plugs, cap, rotor , wires are old.
Nov 29, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Know if my 95 chevy blazer has a spider CPI?
A spider injector is located underneath the intake plenum and this is multi-port. Otherwise you have a throttle body injector system. Vortec engines have spider injectors and they are super expensive to replace ($400.00- 850.00) each ! There is only one spider injector for each engine it has 6 legs/fuel tubes that go to each cylinder.
Oct 10, 2009 | 1995 Chevrolet Blazer
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
118 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
