Question about HTC Wildfire S Smartphone
Washed my htc wildfire wont turn on how do i get my contacts back
Tried attching usb and getting files off computer but wouldnt work
    Master:
  • 368 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Dec 07, 2012
3 Suggested Answers
SOURCE: How to read SD card
I am unable to read vedio file from my memory card in htc wild fire
Posted on Dec 05, 2010
SOURCE: MY HTC WILDFIRE CAMERA WONT
when i go in camcorder and try to video by pressing the start button but insted it just goes back to the mean menu
Posted on Jan 12, 2011
Htc wildfire locked too many pattern attempts
Turn off, turn on again. Get on a computer and access your email account, make sure that's in order. Turning it back on, the phone i mean, eliminates the timer. You wont have to use your email to access your phone, usin instead the normal pattern.
If it wont turn, off, remove the battery, put it back, and turn on the hone ffter waiting between thirty and sixty seconds.
Jul 21, 2012 | HTC Wildfire A3333 Unlocked Smartphone...
How to install softwares on htc wildfire
If you have application files (*.apk) on your computer, you can use HTC Sync to install them to HTC Wildfire S. It is strongly recommended you install only applications that you trust.
Before you begin, make sure that HTC Wildfire S is set to allow applications from your computer to be installed toHTC Wildfire S. To do this, press howtoimage.aspx?id=88185 while on the Home screen, tap Settings > Applications, and then select the Unknown sources check box.
  1. On the Device panel, click Overview.
  2. Click Application installer.
  3. Browse for the application file on your computer, and then click Open. The installation process starts on HTC Wildfire S.
  4. Check the screen on HTC Wildfire S to see if there are additional instructions to complete the installation.
  5. After installation is complete, you can click Disconnect.
  6. Safely remove HTC Wildfire S as required by your computer's operating system.
Jun 01, 2012 | HTC Wildfire
Cannot sync with my computer to my wildfire s mobile
hello Jb,
Setting up HTC Sync to recognize HTC Wildfire S
Connect HTC Wildfire S to your computer using the USB cable that came in the box. When
HTC Wildfire S prompts you to choose a type of USB connection, tap HTC Sync, and then tap
Done.
Wait for HTC Sync to recognize HTC Wildfire S
.On the Device setup screen, enter a
name for HTC Wildfire S.
Click Save. The Device panel then opens.
Aug 17, 2011 | HTC Wildfire
I dont know how to use my HTC Wildfireas a modem.please help
Hello Vincetle,
You need your SIM card inserted on HTC Wildfire S to use the data connection.To use HTC Wildfire S as a modem, you need to install HTC Sync on your computer first.
  1. Make sure the data connection on HTC Wildfire S is turned on.
  2. Connect HTC Wildfire S to the computer using the provided USB cable.
  3. On the Connect to PC screen, select USB tethering, and then tap Done.
Aug 17, 2011 | HTC Wildfire Cell Phone
Data transfer from computer to htc wildfire
You can follow the instructions in user manual...
Jul 19, 2011 | HTC Wildfire Cell Phone
How to copy songs from my pc to htc wildfire
Hi there!
Transferring music files or songs from your computer to your HTC Wildfire is very easy. Just connect your HTC using your USB cable and select "Mount as Disk Drive" on your phone. You can create a new folder inside your HTC with the songs and your Music App should automatically sync it.
Best regards!
Jun 10, 2011 | HTC Wildfire Cell Phone
Hi there my problem with htc wildfire is , when i plug my phone to the pc , the pc does not read it and does not show the internel hard drive of htc wildfire and even the htc sync does not read the...
This issue could be caused by a few things. The first thing I would do is restart the device, then try to connect again. I would then try using a different USB port on the computer to make sure that it was not the specific one I was using before. If the problem still persists the make sure you have installed drivers for this device on your computer and try using a different cable to connect it.
After a bit of searching I found this forum topic that may help you out:
http://www.htcwildfireforum.com/htc-wildfire-troubleshooting/connected-to-pc-but-charging-only/
Mar 02, 2011 | HTC Wildfire Cell Phone
How can I transfer photos from my HTC Wildfire to my computer via USB cable ? I can find no information in the handbook.
You may follow the following steps:
  1. Connect your Phone to PC using USB and select "Disk drive" on the pop-up menu at phone.
  2. At your PC, browse My Computer just like any USB storage device. The pictures you've taken is usually found at F:\dcim\100MEDIA (the drive letter may vary), or better yet search for *.jpg
Feb 24, 2011 | HTC Wildfire Cell Phone
How do i copy music from pc to my htc wildfire
Hi there!
Best regards!
Sep 18, 2010 | HTC Wildfire Cell Phone
HTC Wildfire S Smartphone Logo
35 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
