No picture Came home from work and screen is blank. Restarted pc, faint flicker on screen, no picture.
  • rmdlr Jan 12, 2009
    Monitor is blank. Unplugged and connected to alternate monitor which works fine.
  • 565 Answers
Use safemode to change the resolution maybe its to much, safe mode u can go on boot with F8. also Try this monitor in other computer,
Posted on Jan 12, 2009
    Sergeant:
    Novelist:
  • 326 Answers
If the alternate monitor works fine .its definate that the monitor which is flickering has the problem with the main board or est card.getting it repaired by a proper technician after checking all the other components too is advisable.i dont feel its a do it yourself type of job if you dont have enough monitor repairing tools and knowledge.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, either a monitor problem or computer (video/memory) problem. Pls post back whether it is a laptop or a desktop, brand and model. Initially, a couple of things you can try:
  • check the cables;
  • cycle power on/of;
  • try attaching another monitor to the computer. if it is a laptop, the external VGA connector;
  • any beeping sound;
  • does the computer go through the boot up process, correct sounds, correct lights except no video display;
  • if it is an LCD display, try shining a flashlight at an angle on the display and see if the desktop could be seen albeit very very dark;
  • if it is a CRT monitor, check if your arm would get goose flesh when moved close to the screen.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Sniper:
  • 59 Answers
Hi welcome to fixya there can be a short in your monitor and can be causing it not to show you a picture i would take the monitor to a pc store and have them open it up to see if it can be repaired
  • 13,433 Answers
Try another monitor with the computer and try your monitor with another computer.
if another monitor doesn't work with your pc then the issue is in the computer, or its video card. what brand and model pc you got there?
if another monitor works in your pc then the issue is on your monitor.
    Brigadier General:
  • 5,158 Answers
A component has failed... likely the power section effecting the lamps... disassembly and repair would be required... or replace the monitor
    Genius:
  • 1,913 Answers
First check keybord cpu is workng then check num lock key on keybord press it then check num lock on and off .?if then it is ok.
connwect your montor all cable again.
f problerm stll then refix your ram after open cpu case .
then stll problems put your cmos cell for 15 minutes to reset bios .
  • kishor khatri
    kishor khatri Jan 12, 2009
    ok check resolution of dispaly propertes.
    may be your reolution s not supported by second montor.
    when u power up the computer press F8 key t gives u safe mode and other menu
    then enter in enable vga mode.
    then change reoluiton to 800*600 then apply and ok
My computer comes on just fine, but then while loading the screen goes black. You can hear the computer still working. Sometimes the screen will pop back on but it will be faint and flicker then goes...
Regarding the blank screen, your monitor is most likely faulty - I'm assuming an LCD screen, in which case the backlight is failing, possibly the tubes or the the inverters.
Regarding the fans, you may have pulled the fan leads out of their connectors on the motherboard. Check to see if the CPU fan spins while the computer is switched on.
Jan 03, 2013 | Sony VAIO VGC-JS160J/S 20.1-Inch...
Lexsor 32" widescreen LCD TV
sounds like av panel needs replacing................
cheers
Mar 26, 2011 | Televison & Video
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
Screen is blank
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 13, 2009 | HP Compaq Presario V2000 Notebook
Screen goes black when plugged in
The high pitch sound is most likely a faulty inverter. Most defective screen are caused by a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 12, 2009 | Dell Inspiron E1505 Notebook
Laptop screen blanks out
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 02, 2009 | EliteGroup ECS G900 Notebook
Computer starts up to a blank screen
2 BEEP MEAN PARITY ERROR OR PARITY CURCIUT FAILURE, HAVE YOU INSTALLED ANYTHING NEW THAT HAS MEMORY ON IT, RAM,AUDIO,VEDIO.
ROD
Feb 12, 2009 | Dell Latitude D630 PC Notebook
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
