Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
How do you reset sears elite trio (mod.#795.7754) exterior door control panel ?
SOURCE: Kenmore Elite Trio 795.7519
This is the 1st (and easiest) step to take:
1. Turn power off to the refrigerator (i.e. unplug)
2. Leave OFF for at least two minutes to allow the CPU to reset
3. Turn power back on (plug in)
This solves 98% of these problems with the Kenmore Elites.
Step two would be to call service.
Posted on Apr 26, 2008
huuum
  • 750 Answers
SOURCE: elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 62 Answers
SOURCE: Kenmore Elite Trio - Error msg control panel Er dH -
yOU DON'T SAY WHAT THE MESSAGE IS. EITHER WAY IF THERE IS A ERROR CODE USUALLY ONE OF THE FANS ARE NOT RUNNING OR THERE IS A DEFROST PROBLEM.
Posted on Dec 02, 2008
  • 13 Answers
SOURCE: kenmore elite trio 596.76539500 control
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Posted on Feb 15, 2009
SOURCE: I have a Kenmore Elite Trio Refrigerator. The
I have the same problem what is the solution
Posted on Dec 22, 2009
Kenmore elite trio
The door switch that controls the lights is acting erratically. Replace it
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
Sep 23, 2017 | Refrigerators
My kenmore elite refrigerator (trio) model # (p) 75523 serial# (s) 10477898ev the refrigerato is not cold anymore, but the freezer is working fine. the compressor is hot, and the fan is working. ...
I am pretty sure that two companies made the Trio for Sears and I will help you. At this point I believe you are having a defrost or damper control problem. Would you look around the frame or freezer drawer and see if there is a different number than p75523 because Sears uses that number for another reason than the true model number. You may find a Maytag number or an LG number on your model. Sears places numbers like this for example 323.26589 as a model number. I am ready when you are. Sea breeze
Dec 12, 2009 | Refrigerators
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
Kenmore Elite Trio
If the fan beind the rear cover inside the freezer isn't running it can cause circulation problems one of which is freezing in the drawers. The fan may not run when the door is open so hold the door switch down. It should be running when the compressor is running.
Aug 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio 596.76539500 control panel says OFF.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Dec 02, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
