Question about HEWLETT-PACKARD Pavilion dv4015CL PC Notebook
How to fix wireless connection problem with pavilion dv4015cl laptop using intel PRO/Wireless 2200BG Network Connection
After I changed the internet service provider and installed its new router this is the only PC that has connection problems. It stopped connecting, and when it rarely does it ads a number 2 after the name of the network. I've reset the router and set up a brand new network, but it still does not connect.
  • 564 Answers
If you open up a command prompt (if you're using windows 7 just click start and type cmd then right click the icon that comes up and choose run as administrator, if using xp click start and you should see command prompt and do the same.) when the window opens type ipconfig and press enter. look at your ip address, if it starts with 169 type ipconfig /release and press enter wait for it to do that then type ipconfig /renew and press enter. check your ip address again, it should start with 192. then close the window and try to open the web browser.
Posted on Dec 07, 2012
  • 186 Answers
SOURCE: When i turn on my wireless connection the light
Go to device manager and then go to wireless adapters and re-install device driver. You can even uninstall the wireless adapter and reboot the system and it should re-install the device and drivers for you.
Posted on Feb 24, 2011
  • 214 Answers
SOURCE: I can't figure out how
I just want to know are you using wired connection or wireless?
If you're connecting using wireless try going to this link on how you can setup your wireless connection.
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I suggest try to call your ISP to setup your network connection.
AnEspera
Posted on Apr 19, 2011
KittyTech
  • 324 Answers
SOURCE: I have a new HP Laptop G56 runing windows 7, when
Try a hard reset on the router first;
Turn router around;
Find the small pinhole usually located by the power cord;
Stick something like a paperclip in it and press down firmly for 1 minute;
wait until you see the lights blink and then go out;
Then; unplug the power cord from router for about half a minute;
Then, plug it back in.
Try it again and see if it stays on.
You can also try and upgrade your firmware if this doesn't help at all.
Click this link and follow the instructions for updating your firmware.
http://forums.whirlpool.net.au/archive/322832
However; If your router is old or damaged, it may need to be replaced. They shouldn't continue to reboot over and over.
Please rate this solution if it was helpful to you. It doesn't cost anything to rate and it is greatly appreciated!
KittyTech
Posted on Jan 06, 2011
  • 265 Answers
SOURCE: I am trying to connect
Hi ,
you need to go into your router settings and see if you have it set correctly , 2nd- check your firewall settings to make sure there are ok .................let me know if this works , if not we will go into more detail in the network settings .........................Good luck Roy
Posted on Aug 27, 2011
Geekman
  • 32281 Answers
SOURCE: My HP Probook 4720S has
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
If the other laptops are connecting to the wireless router, then look at the wireless card configuration in these laptops and apply the same settings to your HP Probook wireless card.
Posted on Sep 05, 2011
Hi Just reloaded windows xp sp3 on my laptop and lost my intel 2200bg drivers for the wireless. Cannot connect to the internet so cannot get the drivers back automatically how do I progress from...
Can you use a wired connection? If you can, then download the driver from Intel. IF not, get a flash drive, and use a machine that can get to the internet. Download the driver from intel, save it to the flashdrive, then insert the flashdrive in your laptop, and install the driver.
You can also get the driver from the manufacturer of the laptop.
Jan 21, 2011 | Intel PRO 220BG Wireless Network Card
My pc crashes when I start a wireless connection using the computer wireless button. Network card is Intel Pro 2200BG wireless LAN. Have reinstalled the driver with no success.
try this...
1. download the updated driver
2. go to the device manager then uninstall the wireless driver
3. restart your computer then reinstall the driver
4. restart your computer for the last time and the driver will be installed properly
Jan 14, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
Describe your Intel PRO/Wireless 2200BG 802.11g/b
SO you are not able to connect tyo the wireless network.
what is the operating system on your computer ?
Click Here for more info wireless connection
Oct 08, 2009 | Intel PRO/Wireless 2200BG...
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Wireless network found
If it cannot find any networks, check to see if there is a wireless on/off switch on the computer - look carefully some are well hidden. The switch turns the antenna on and off but windows still detects the network adapter and thinks everything is ok.
Sep 07, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Long load up time on windows startup
The chat got diconnected, apologise for the same. Some times that chat tool acts up.
What we need to do to help you resolve the problem is to uninstall and reinstall the wireless driver.
1. Connect the ,laptop to the wireless router using a network cable. So that we have stable internet connection
2. Click on start and go to control panel, open Add or remove programs
3. Uninstall Intel Pro wirelss and click uinstall
4. Restart your computer
5. Download the updated driver for the wireless connection from the following website
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62875
Save the file on your desktop: 7kwc50ww.exe
6. Double click on the file and install. Reconfigure the wireless settings
and it should work fine
Thanks
proton
Aug 01, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
I have an Intel PRO/Wireless 2200BG.... Modem
That is hardware issue ( the modem is bad ) replace the modem and it will solve your issue .
Jul 24, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Reboot necessary to find ISP server
2200BG is a very old Intel wireless card. Its driver had a lot of issues that were fixed over the years. Try the latest driver from Intel site: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637&lang=eng (make sure to choose correct OS).
Jan 11, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
HEWLETT-PACKARD Pavilion dv4015CL PC Notebook Logo
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
