Question about Smeg KSED65X-1 Kitchen Hood
The power seems to have gone
The light bulbs blew in the hood, I replaced them but neither the lights or the fan is working.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Fan & lights were working. bulb blew out in flash. replaced all bulbs. fan works. lights do not. what is the problem?
Hello :
It seems that you have problem on LED flicker PCB .
See the pictures to know what I mean :
This must be happened when the lamp blew out .
I hope this will help .
please rate !
Apr 22, 2010 | Hunter Dryers
Bulb blew on cooker hood and I replaced both. Light still won't work and neither will fan - both working fine until bulb blew.
hello. I can assist you. begin by going to the electrical panel for your home. You will be looking for the circuit breaker or fuse that controls this hood. Chances are the actual problem is that the fuse blew, or the circuit breaker kicked off. To reset, replace the fuse with a new one of the same amperage, or turn the breaker on and then off and then back on again.
Nov 18, 2009 | Televison & Video
Blew the rear parking lights. Front parking
If they are both gone, you either have a bad ground wire or broken wire. See if you have power back there. The bulbs could be both burnt out.
Oct 15, 2009 | 1993 Mazda 929
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Cooker Hood problem
check the printed circuit board behind the switches - maybe when bulb blew it took out some of the track. usually repairable by soldering in a link over the damaged track. have you checked the fuse as well?
Jun 19, 2008 | Kitchen Ranges
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Smeg KSED65X-1 Kitchen Hood Logo
265 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
