Question about Dryers
I have an lg tromm electric dryer model number dle2516w. I had to replace the control board pt#ebr33640901 and when I put it in it makes a chime noise when you push the power button that is different then the original chime and I have no cycle selection switches. Everything is plugged in and there is the correct voltage going into the dryer.
SOURCE: Whirlpool Calypso Dryer Electrical Problem
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Posted on Nov 11, 2007
  • 31 Answers
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
Your motor has fried. It isn't in the Control Panel, the SENSES light wouldn't turn on if it were the CP. If you go to your closest Home Depot, ask the front desk for assistance with Dryer Motors. They will guide you through to get you the right one. They will even tell you how to install it. When you replace it with the new motor, the Dryer will work fine.
If this helps at all, please rate this a FixYa. - Evolution
Posted on Jul 17, 2008
  • 130 Answers
SOURCE: dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Posted on Jan 29, 2009
SOURCE: My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Posted on Apr 11, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
LG ELECTRIC DRYER DLE2516W: ONLY ON DELICATE SETTING, CYCLE STOPS AFTER ONLY 5 MINUTES?
if this stops after only a few minutes and all the other cycles work fine then u have a faulty control board which tell the unit what to do
Aug 21, 2009 | LG DLG5988 Gas Dryer
NEED TO REPLACE HEATER ELEMENT
You should be able to take off the back panel and see it. The heating element is USUALLY an easy fix. Let me know if you need any further help.
May 04, 2009 | LG DLE2516 Electric Dryer
LG Tromm door reversal
IF YOU SWITCH THE DOOR YOU MIGHT WANT TO MAKE SURE THERES NO SWITCH OR ANYTHING THAT THE DRYER READS TO SAY THAT THE DOOR IS SHUT OR OPEN IF NOTHING THEN IT SHOULD BE A PRETTY EASY SWITCH
Mar 09, 2009 | LG DLE2514 Electric Dryer
LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Jun 11, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
