Question about Sony Ericsson W800i Cellular Phone
Charge meter problem
I have aw800 when in charge ,bettery meter is in green color. but when charger is remoned bettery meter shows no color
I have sony ericsson w800i
when i put to phone charge does not work charge, sometime connect charger & start charge
Posted on Jan 15, 2009
How long do you charge it for
Until the green light o the charger comes on or the charge meter shows one amp or less. If the batteries were drawn down too far the 5 amp charger will NOT recover the batery. In that case seperate the batteries and charge each one with an automotive battery charger.
May 08, 2014 | Pride Jazzy Select 6 Indoor Power...
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 | Cell Phones
My Jazzy select six sometimes charges sometimes(most of the time) does not. The charger shows red and green when first on then in the morning both are green, but the joystick shows no charge. The...
After charging overnite get a digital voltmeter set it to 200 volts dc and plug the leads into the 2 outter holes in the charger port located under the front of the joystick. If the charger works properly you should read 26-27 volts on the meter. If you are reading 24 volts or less then have the charger checked it should be putting out 27-30 volts or so. I would also have the tech check the batteries under load and check the wiring harness from the joystick to your controller. Hope this helps
Oct 31, 2010 | Pride Jazzy Select 6 Indoor Power...
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
Battery will not take a charge, i do have it plug in now,it's showing that it's connected.
you should check ur charger first if it is ok then check ur charing pin inside ur device.check ur bettery also some time betteries have problems.
Dec 04, 2009 | SanDisk Sansa Clip MP3 Player
Chaina n98gb
plz change your mobile bettery
May 30, 2009 | Nokia N95 Cellular Phone
Charging problem
Dear, Sir I have a Mob. 6681.My problem is when i charging the ph. its showing charging but don't showing full charge & When i removed from charger its show low bettery & off.
May 24, 2008 | Nokia 6681 Cellular Phone
Sony Ericsson W800i Cellular Phone Logo
85 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
