Question about Singer 3820 Mechanical Sewing Machine
Where is the timing belt on a Singer 3820 located
It has not been working properly for some time now. So i took it apart to clean it cause i thoght it was just lint trapped in. but now it wont sew. the needle gos down but it dose not sew. Please help!!!!!!!!
  • Singer Master
  • 1,564 Answers
The timing belt is inside the bottom of the machine.
Posted on Dec 07, 2012
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
bargainbox
  • 1388 Answers
SOURCE: under fabric bunches of thread and the needle stops after seconds
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Bargain Box
Posted on Sep 02, 2009
  • 980 Answers
SOURCE: my singer sewing machine no. 127 vibrating shuttle
There are no adjustments at all on that model, it has to be down to the needle for some reason
Posted on Nov 02, 2009
I have a Singer Inpiration and the timing is off. It is belt driven How do I adjust?
How do you know that the timing is off? What is it doing/not doing that makes you think that?
It is possible that your needle is either backward (flat part is not away from you) or it is not high enough in the needle clamp. That can cause the very same symptoms as a machine that is off timing.
Feb 20, 2015 | Singer Sewing Machines
Singer 7463
Check manual for proper threading and insertion/orientation of needle. Or...needle damaged.
Aug 09, 2014 | Singer Confidence 7463 Computerized Sewing...
Handwehell asembly
Always take a photo before you take something apart to know how to fit it together again. Is the belt too tight? is it the correct belt? Redo the procedure again and check carefully when putting it together again. Move the hand wheel a few times during assembly to make sure its loose and the belt sits properly on the motor and hand wheel gear.
Jan 11, 2014 | Singer 3116 Simple
Bobbin casing not in properly, needle stikes
take the bobbin assembly apart and replace it properly.
Jul 19, 2011 | Singer 3820 Mechanical Sewing Machine
I have Singer 5040c machine i was cleaning this machine it was working fine before, but machine is breaking needle all the time ,i can't sew anything, i just remove belt from bottom part cleaned it...
Your machine needs a professional to fix your timing and tune it up. You may have messed up the timing when you took off the belt. It is worth getting it fixed.
Sep 19, 2010 | Singer 5050 Mechanical Sewing Machine
The bobbin thread will not feed up to the sewing deck
Get a q-tip and clean out all of the lint from the bobbin area. Then make sure the bobbin case is in properly. Make sure you're using the correct bobbin size. Then thread the bobbin again & see if it's working properly
Jul 16, 2010 | Singer 3820 Mechanical Sewing Machine
I've removed the Timing Belt on my Wifes 3820
adjust your tension, change your needle and adjust also your rotating bar.
Mar 27, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 3820 Mechanical Sewing Machine Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
