Question about IBM Wheelwriter 30 Typewriter
Space lights flashing
We have awheel write that the lights on the side were the size of line space is flashing on and off what do we nee to do
  • 3 more comments
  • Anonymous Jan 12, 2009
    We have
  • liljess00 Jan 12, 2009
    We have an IBM Personal Wheelwriter 2. Well, on the right side where it says, 1, 1 1/2, 2, 3, the lights keep flashing and it keeps beeping. I can't type anything. The typewriter will not respond. I have tried unplugging it and turning it off and on but nothing. Help!
  • newshottreal Apr 02, 2009
    IBM Personal Wheelwriter 2 beeps 6 times at power up and space LED 1 and 2 flash continuously. Machine is locked up.
  • liljess00 May 11, 2010
    where can i found ww1000?
    They are flashing on. I hear three beeps. It's a 6781-025, 50-60HZ if that helps?
    Novelist:
  • 297 Answers
  • IBM Master
  • 3,594 Answers
With the little info. you have given I would suspect the keyboard id going bad. See my tip under WW1000
Posted on Jan 12, 2009
  • Dick O Reilly Jan 13, 2009
    Check under lexmark
  • 328 Answers
Tell me the pattern. Are they flashing or on solid? Do you hear beeps. Count the beeps. Is it a WW 30?
Can propane gas lines cause pilot lights to go out?
It could be a blockage in you pipes or blocked pilot on water heater nees cleaning or your pipe size is too small for both or you are low on gas or reg on tank not working ie wrong working pressure .
Dec 28, 2012 | Heating & Cooling
Just bought a used frigidaire crown series gas dryer need a hook up line in the back to connect the gas. Is it a certain size i need or how do i find out
The line size depends on three things...the BTU of the burner and the length of the line...and the types of gas..Natural or LP
To find the line size you nees a chart that gives you the sizing based on these factors...
Here is a chart for Natural gas and I'm sure LP is also in thei site if you need that...
http://www.engineeringtoolbox.com/natural-gas-pipe-sizing-d_826.html
heatman101
Oct 04, 2010 | Frigidaire FGQ332ES Gas Dryer
CAn you give me size specifications for the Kenmore side/side refrigerator model # 106.9512811? It was purchased in 1993 and I have the books and parts list but see no size spec. I am wanting to replace...
You would be better off measuring not the refrigerator you are wanting to replace, but the space within which it must go. If you go to the store with current refrigerator measurements, instead of the space available, you wont know what size you can get.
Aug 13, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Dont show the space
While flash drives are advertised with a capacity of 2.00GB or some other rounded size they are never actually this size. Flash memory is cylindrically rounded off, at a smaller size. Also some of the space is reserved for system files and boot sectors. The actual capacity is typically between 80% and 90% of the advertised space.
Jul 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you set up (or turn off) double spacing on an IBM Wheelwriter typewriter?
The older models have a key on the R. side that says line space, press that and the lights will change to indicate spacing.
On the later ones you must use the code key with with the line space key in green on the R. side.
DickyO
Jan 20, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Jul 01, 2009 | IBM Wheelwriter 30 Typewriter
SAMSUNG 225 UW
yes u will nee dto upgrade video card to suport that native resotion of your screen hi 1440x900 ect ok wide need better video card ok least 100 doler one
Feb 06, 2008 | Samsung 225BW LCD Monitor
Flashing lights
You have a keyboard problem. The rt. connector has 7 contacts bussed together, wrap a piece of foil over that portion of the connector and plug it back in. BE SURE TO COVER ONLY THE 7 BUSSED CONNECTORS!
Nov 26, 2007 | Lexmark Wheelwriter 1000 Typewriter
Will not type
If the 1, 2, and 3 line space keys are flashing in order, you need to change the two AA batteries that are located inside your typewriter.
May 23, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
364 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
