Question about Curtis DVD1041 Player
Remote won't work but can manually operate
Checked remote's batteries they are good but does not function. The player does function
    Genius:
  • Curtis Master
  • 2,432 Answers
You do the camera tricks just to ensure if the infra red sensor of the remote is working. get a digital camera turn it on,then get the remote controller. press any button at the remote controller pointing to the digital camera, if you see a light at the display of the camera then the infra red sensor is good but if no light either the sensor is worn out or the circuit was defective.
Posted on Dec 07, 2012
Functions on Sharper Image remote control won't work
Try it with an other code to your device.
Feb 17, 2013 | Televison & Video
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
DVD has been working fine but recently moved it to decorate. Now all is I get is 'Hello' when it starts up and none of the functions work. It won't even open or close manually?
see this causes and fix it God bless you
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic
Sep 23, 2012 | Televison & Video
Recommended replacement remote for 32c11ou
i would make sure you have good batteries in remote and if you have a cell phone with a camera you can point the camera at the remote control where the bulb is that you point at the tv and push a button on the remote control and the light will show up in the camera as a blue light the camera will pick up the ultra violet light that your ***** eye won't see if still bad almost all universal remotes will work but usually problem is battery or corroded battery connectors good luck
Aug 05, 2012 | Toshiba Televison & Video
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
I just purchased a new remote for my Delphi XMXpressRC. The remote won't operate any functions. My old remote still works but is worn out. Does the new one need to be programmed?
There is no programing necessary for the remote. Are you sure you have the correct remote? It should be this one: http://www.tss-radio.com/products/xm-universal-xpress-remote-control.
Does the remote you have operate anything on the receiver? If not, I would check the battery. (Maybe try swapping batteries with the old one to see if that makes a difference)
Jun 07, 2011 | Delphi XpressRC XM Satellite Radio...
HOW DO I OPERATE THE TV WITHOUT USING THE REMOTE
Solutions: 1) on the side of the TV there should be buttons to operate functions such as volume or channel.
2) purchase a replacement remote
3) purchase an all in one / multi function remote, and program it using the codes provided in the manual
May 04, 2011 | Toshiba Televison & Video
Remote won;t work
Hi
if the battery is new, you need to replace the IR in the remote control this is the bad parts thats why you can not operate.
Thanks!
Jun 06, 2009 | Daewoo DVD Player
Curtis DVD1041 Player Logo
127 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
