Question about Hardware & Accessories
Wood work need to change saw blade
    Sergeant:
  • 468 Answers
Try looking to amazon. I'm got mine with them and got my bandsaw blades on www.sawblade.com
Posted on Feb 20, 2013
Can I still get saw blades for this scoll saw if so need to know where and part number
most scroll saws use a standard length blade with standard end fittings
try a good tool shop or wood working tools supplies for blades for your machine or any shop that sells wood working machinery
Jan 06, 2016 | Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
New blade tares threw the wood. its hard to push the wood threw the blade
Are you using a new band saw blade? Are you running on a correct speed. I suggest to change the blade. I got 201 Carbon blade from http://sawblade.com/ . Also, make sure you're in right speed so that the blade will make the cut. Don't feed it so hard, let the blade do the work.
Jan 27, 2014 | Ryobi 9" Band Saw Model Bs903
Would I be able to replace the blade on my scroll saw? How would I go about doing this?
It is possible to replace the balde on your scroll saw when it gets dull. Make sure that you do change the blade to be very careful because the new one will be very sharp. Following the instructions on this site will help you out. http://www.doityourself.com/stry/how-to-change-a-scroll-saw-blade#b
Jan 02, 2014 | Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
How to change blades
unplug it. remove the bolt in the center of the blade. the blade will slip off then. a wrench for this should have come with your saw. if not, use any properly sized wrench. if needed, pull back the blade guard, put the blade on a old piece of wood, push down on the saw and use the wrench. the wood and your pressure will stop the blade from turning as you loosen the bolt
Feb 12, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
How do I lock the spindle in order to change the blade?
As long as the threads on the arbor and the nut are in good shape, you don't really have to hold the arbor from turning, just the blade. Use a block of wood in front of the blade with the blade raised all of the way. Put the wood down in recess in the table in front of the blade and just pry against the blade. This works almost as well on the back of the blade when you tighten the nut. When you are tightening, the teeth are not pointing to your advantage, but you don't need to tighten the snot out of it.
Jan 25, 2010 | Craftsman 10" Table Saw
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Hardware & Accessories Logo
13 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
