Question about Toys
Mini phantom helicopter operating problems
Banks left or right when throttle up and it crashes. Can't go more than 2 in off ground without crashing. No directional control as airborne.
  • 54 Answers
Throttle slowly push on, until you fly the plane slowly so far (oneself fumble balance hovering position. But the movement wants slow, after all, the air force and reaction force have a reaction time)
Trimming is your plane total 360 degree turn the regulation has two screw rotation speed, let autobiography speed equal, also will not autobiography, how to adjust to the half empty when hovering in the opposite direction to the plane of the autobiography twist
The direction of the plane is you another joystick control and control is go around and control is to adjust the direction
Posted on Dec 07, 2012
  • 62 Answers
SOURCE: My eagle rc helicopter wont fly
replace the rotors and it will fly
Posted on Sep 03, 2009
SOURCE: crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
SOURCE: MY YIBOO MINI HELICOPTER ONLY SPINS ROUND AND
Same thing happened to mine if its the same problem. Check if one of the rotors is chipped.
Posted on Feb 11, 2010
bayyagg
  • 1672 Answers
SOURCE: Hi i have just got
The spinning of the whole helicopter is cause by the rotor at the rear.
Look and read the manual on how it could be adjusted. There is an adjustment on the main board, that controls the speed of the motor.
if it doesn't work, you have a defective motor at the rear or the little electronic ic servo on the board.
Hope that helps you out!
Thanks for using Fixya!
Posted on Dec 11, 2010
SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
Posted on Jan 13, 2011
Why does my new 3.5CH heli only spin on the ground & lower blades aren't operating. Won't fly. What gives?
Make sure that you charge the batteries overnight. Low battery power will cause loss of power and loss of lift.
Nov 08, 2014 | HobbyTron Phantom 3.5CH RC Helicopter...
It keeps crashing
use the controller change the setting to the L and R dont setup in the air make it just move along the ground when doing it adjust it up till its stops. failing that the check the blades are straight. hold in hand at bottom and turn on look at the blades as they go round.
Dec 23, 2013 | Protocol Spir 3.5-Channel...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
I bought 3 of the Syma S107 RC Heli's because it said the remote had 3 different channels. I see the Channel a,b,c on the transmitter but I don't see how I assign different channels to the 3 heli's and...
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Oct 31, 2010 | SYMA Toys industrial New Syma S107 Mini...
Toys Logo
156 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
