Question about GE Cg 9808se Hq Vhs Movie Video System Camcorder Loaded W/ Remote Bundle Man
How do you operate the GE cg 9808se vhs camcorder
How do I know if the battery is charging or if I need a new one?
Your need a volt meter
1.read the voltage of the battery
2.charge battery 1/2 hour
3..read the voltage of the battery if it has increased the battery is charging
Jun 24, 2016 | GE Cg 9808se Hq Vhs Movie Video System...
Need pc driver for panasonic nv vz57
I don't like to answer about things "I don't Know" but I've never heard about a driver for a Panasonic NV-VZ57EN VHS-C Analog Camcorder.
What makes you beleve there is any? For which operating system? What is it supposed to do?
Aug 31, 2015 | Panasonic NV-VZ57EN VHS-C Analog Camcorder
General electric hq moviemaker cg 9908 how do i no if batterie is charging
On some chargers the light goes off when charged, read the manual it should tell you. On other chargers you guess or buy a smart charger.
May 25, 2014 | GE Cg 9808se Hq Vhs Movie Video System...
Is there a way to hook the Camcorder straight to the TV. The vhs adapter I have doen't work.
Here's a link to the manual for your camcorder. Take a look at page 11. There are composite (dont confuse with component) audio and video outputs. If your TV has the same type of inputs, then a direct connection between the TV and camcorder is possible. Otherwise, you will need a composite video converter to change the format to a specific channel, usually 3 or 4.
On the VHS adapter, try changing the battery (also in the manual as well) to restore operation.
Sep 27, 2010 | RCA CC6151 Camcorder
How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
Jan 14, 2009 | JVC Everio GZ-MG20 Camcorder
Ge cg515 vhs c camcorder
This camera is compatible with panasonic and universal batteries. 6 volts NiCd rechargeable with a dedicated charger.
Nov 27, 2007 | GE CG515 VHS-C Analog Camcorder
GE Cg 9808se Hq Vhs Movie Video System Camcorder Loaded W/ Remote Bundle Man Logo
43 people viewed this question
Top GE Video Cameras Experts
Securetech...
Ravi
Are you a GE Video Camera Expert? Answer questions, earn points and help others
