Question about Samsung SGH-E316
Can't Connect Wifi. Using att uver router
How to set up my printer to my Mac Book Pro wirelessly
Since replacing our Wifi and router and purchasing an ATT combing wifi/router
try this link
AT Wi Fi Support and Customer Service
at any rate ATT should be able to give you documentation for your equipment
Jun 24, 2015 | Apple MacBook Pro Laptop Computer with...
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Bsod 0x1000008e with windows xp and at&t lightning connect
If you are using the ATT software, that's your problem. The Sierra Wireless 'Watcher' software is much better and can be downloaded at the following link.USB Connect Lightning for AT&T
All the best
Ben
May 25, 2011 | Sierra Wireless ATT Lightning USB Aircard...
All of a sudden, I can't connect to the internet. My network connection is asking for a security key. I have never had to do that before & I have no idea what it is. Please help.
Someone nearby may have created a new wifi network, and your computer is trying to gain access to it. The first thing to do is to verify that you are indeed trying to connect to your own wifi network by checking the SSID of the network. Or, you can physically move closer to your wifi router and see if you can then connect as expected.
If you're still having trouble after that - you'll need to access your router's setup pages via a computer that has a network cable connected between it and one of the LAN ports on the router. Login as usual with your username & password credentials and then change the SSID, encryption and the username & password information. If you are unable to login, then it is very possible that the person(s) that took over your wifi have also attempted to lock you out of it. You'll have to consult your router's manual to learn how to perform a hardware based factory reset. Once this has been done, you'll need to set up your variables for your network again. Make sure you secure the wifi to prevent unauthorized access again. This mean using WPA instead of the comparably very weak WEP security AND then locking down access to the setup page with a new username and password.
I hope this helps and good luck. Please rate my reply. Thanks.
Apr 15, 2011 | Computers & Internet
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
LG Incite Wifi Setting
settings
connections
WIFI
connect to "internet"
authentication "open"
encryyption "WEP"
I let it assign it's own IP address
Start -> Settings -> Connections tab
WiFi -> Network Adapters tab
select "The Internet" and then select Broadcom 802.11 DHD Network Adapter
and
Start -> Programs -> Tools -> Proxy Manager
click on "Disable Proxy" and hit OK
Also, make sure you set the browser Home address to a valid address (otherwise it would complain about a connection loss each time you open the browser)..
If that doesn't help you then your lost.
Jan 02, 2009 | Computers & Internet
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
Aug 03, 2008 | 2wire (1000-400108-001) Router
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Samsung SGH-E316 Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
