Question about Acer Ferrari 1100 Notebook
Just got second hand ferrari 1100 and it just has black screen?Used F8 to get the harddrive light and put CD in which is spinning but still black creen also tried external screen?HELP PLSE?
Black screen but used F8 and it made noises and the HD light flashed and put CD in which was spinning?STILL BLACK SCREEN?
  • Acer Master
  • 7,627 Answers
If your external monitor isn't working, it may be your graphics. You could open the case and search for loose connections or components. It's difficult to say without opening the laptop. Your specs say you have integrated graphics. What kind of noises? Is it coming from the HDD? the DVD rom?
Posted on Dec 07, 2012
  • 1 more comment
  • bartlettkarl
    bartlettkarl Dec 07, 2012
    Thanks for reply.My partner likes to take things apart and can usually fix them?This has stumped him at mo!The noise is the fan and the DVD rom but only using F8 to get started
  • max carson
    max carson Dec 07, 2012
    Make sure the fan and vents are free of dust. If you can see a "ghost Image" in the screen in a very bright light it's most likely backlighting. If you get Nothing on the screen, not even a white cursor in top left of black screen . The computer boots? Do you hear sounds? You said you can load a CD?
  • max carson
    Take a look at this procedurehttp://www.youtube.com/watch?v=2Yi6GNFcP...
  • 10406 Answers
SOURCE: Acer Ferrari 4000 power up with blank screen, no
If you cannot "press DELETE to enter setup", then it's the motherboard, or the battery, or the AC power-supply that has the problem.
Since it's likely that at least one of the battery and the power-supply are working, it's probably the motherboard (or the CPU on the motherboard) that is failing.
Take the computer to a qualified technician.
Replacing the CPU is possible, and is not very expensive.
Replacing the motherboard is possible, but is very expensive
(a few hundred dollars for a replacement motherboard, plus $100 for the technician's time to disassemble/replace/reassemble).
The only "good" news is that your files on your disk-drive probably are intact, and can be read and transferred to a new computer.
Of course, you can try to sell the "dead" computer on eBay, so that somebody else can "frankenstein" your computer with their computer, to combine two dead computers into one working one.
Posted on Nov 11, 2009
  • 62 Answers
SOURCE: acer 9300 black screen at start, tried some things, didn't work.
bobcat915,
I have encountered this situation before myself and it was due to the frequency range and resolution that the external VGA monitor can handle. First, try dumping down your screen resolution to an 800x600 on the laptop itself. Save the setting and reboot to make sure it stays. Next connect the external monitor and reboot the system with it plugged in (power and data). See if the monitor will display anything. Note: You may also have to look at the frequency setting of your video card in the laptop in order to match it with your external monitor.
I can't imagine that a bad CMOS battery would be the issue. Does the screen on your laptop work without the external monitor plugged in?
Posted on Apr 19, 2009
shahabdun
  • 249 Answers
SOURCE: acer 8920 intel x3100 lcd and external monitor blank or black
Problem with the Power supply.
Posted on Jul 19, 2009
SOURCE: turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Posted on Jun 15, 2010
shibuda
  • 1812 Answers
SOURCE: Acer Aspire 9300. Symptoms:Powering up,
Did you change the HDD ?
Did you change the MOBO?
Please try to change the battery or charge the battery again or can check by your nearest technician.
If there is any courser blinking any on the screen think your LCD is ok.
The HDD is defected.
If there is no courser ,The hdd is spinning thing LCD could be damaged,
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Posted on Jan 25, 2011
Testimonial: "Did change the MoBo & Battery & CPU. Did NOT change HDD. Screen black (same on external monitor) No cursor, no sound from HDD. Michael"
My acer ferrari 1100 problem is after opening few second it bacam black cant seee anething
Most people remember if they have pressed F4, to switch to an external monitor, or not
It could be a GPU issue or a backlight problem. Try an external screen.
Feb 25, 2014 | Acer Ferrari 1100 Notebook
Cant get password to work on my Ferrari 1100 acer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dec 17, 2012 | Acer Ferrari 1100 Notebook
1100 ferrari acer power but no screen?
Assuming no BIOS is displayed
  • Memory could be bad
  • Motherboard could be bad
  • Backlight could be bad
  • Inverter could be bad
  • Screen could be bad
Pull the memory modules out and boot the computer if it makes it to BIOS and then beeps at you one or more of the memory modules are bad, replace one at a time if you have more and test until it breaks again then you know which to replace.
To Test the inverter and backlight hook up an external monitor and boot the computer. If it displays correctly on the monitor then you've narrowed it down to a bad screen, inverter or backlight. Backlights don't usually go out.
Remove the monitor and boot the computer. Shine a flashlight on the screen and look for a very faint image of what should be displayed. If you see one I'd start by replacing the inverter. If you don't see one the screen is bad.
If none of this worked then replace the motherboard.
Dec 15, 2012 | Acer Ferrari 1100 Notebook
Missing NTLDR message, cd does not start ,have no floppy, this is a 503gr. F8 does display but does not continue to selected item, get black screen. Does a processor cause this failure?? Have original...
Your CD is not starting as it is not configured for first boot device. I am not sure on which function should be used to get to Boot Menu however you may want to try using either F2 or F12. Then its all about changing the Boot device fromHard Drive to CD. Once Changed follow the steps mentioned below,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Once all these steps are completed make to change the boot device to hard drive from CD rom.
Jan 07, 2011 | Gateway 503GR PC Desktop
Ferrari 1100 cd drive wont read oor write
Please try this :
Open the registry under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
[to open the registry, vista or 7, navigate to start, then type in regedit, choose from list, right click and say open as administrator. On XP, navigate to start, choose run, type in regedit and hit enter]
Then find the DVD & CD ROM key under above value.
Under the DVD & CD ROM key, find the values UpperFilter & LowerFilter and delete both seperately. Reboot machine and recheck. See below for picture
May 28, 2010 | Acer Ferrari 3200 Notebook
I have acer ferrari 1100 I can't chanf=ge the
That is the visus problem....
Best way is format the hard disk and reinstall the os.
Thank U Sir...
All The Best...
Apr 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
I got LED lit on but black screen. No harddrive movement or sound
when you power up the computer press F8 key if you can see safe mode and otehr menu then you can do it.
Enter in enable vga mode then change screen resolution 1024*768
Jul 27, 2009 | Acer Aspire 5920-6727 Notebook
2 Compaq TC 1100 - neither boots
Try first to clean you memory using the eraser and put it again. Then u can use flashdrive in installing your windows. It can be that your cd/dvd drive is the problem. Hope this can help.
Mar 27, 2017 | Compaq D70045-236 Tablet PC
Acer Ferrari 1100 Notebook Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
