Question about ASUSTeK COMPUTER ASUS P8C WS - Motherboard - ATX - LGA1155 Socket - C216 - USB 3.0,
Asus P8C WS error FF onboard LED - ASUSTeK COMPUTER ASUS P8C WS - Motherboard - ATX - LGA1155 Socket - C216 - USB 3.0,
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: asus P8C WS error code 55
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
When a computer completely fails to boot or to provide any sort of power on self-test (POST) beep codes, the cause is either a hardware failure, lack of power or a bad connection.
To solve these problems, it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer.
From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them.
Test the AC power to make sure there is power to the outlet. Inspect the back of the power supply to ensure the power cord is fully seated, the power switch is on and the voltage setting is set to the right voltage, which is typically 110 volts.
Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located.
Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system.
This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
Disconnect the drives and remove all of the expansion cards except for the video card, and try to boot with a bare system composed of only the power supply, motherboard, CPU and cooling fan, RAM, and video.
Attempt to start the computer again. If the system boots, reinstall the removed items one at a time until the system again fails to boot, and then replace the component that is causing the failure.
If the bare system fails to boot, swap in known good components for the motherboard, RAM, video card, power supply and CPU until the system boots.
Swap components into a working computer one at a time until that system fails to boot in order to locate problem components.
Hope this helps.
Posted on Nov 22, 2012
No display of my motherbord
The problem is that the enable jumper for the onboard video is not installed.
Note: The POST beep should be occurring, to indicate there is nothing wrong with the motherboard.
If the motherboard onboard video is bad, install a graphics card.
Aug 24, 2015 | ASUS Computers & Internet
Onboard memory
what error is coming up? if its like mine then all you need to do is get into the bios and change the boot setting to boot off the disk or flash drive and then put it in the drive and install the operating system that way no memory problems.
Dec 07, 2013 | ASUS K50IJ-C1 Notebook
Asus P8C WS error code 55
Hope this helps.
Nov 22, 2012 | ASUSTeK COMPUTER ASUS P8C WS - Motherboard...
Asus A8V-E Deluxe dead, need expert help !!
If there is a system error, you will hear a beep code.
Nov 30, 2017 | Computers & Internet
Motherboard will not power on. Onboard LED
did you check power supply? are there any beeps during post? is the fan running on the processor? did you try removing everything and reassembling to see if it works. let me know and good luck
May 02, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
On my motherboard the counter shows FF what does it mean, and how can I fix the problem(my monitor doesn't switch on)
The FF on the board just means that the motherboard completed an attempt to boot. That's it. Very vague i know...but in every instance of the ff code the board had to be replaced. Error code 2D may indicate a video problem...ultimately we could never know what to expect with generic codes like that...As an engineer I I would go a step further and try disconnecting the hard drive to see if you get the computer to get to the BIOS which would indicate a failed drive or corrupt OS Otherwise you are probably correct in thinking you might have a video problem which is onboard and would still require a board replacement. But save yourself the trouble and get another computer which doesn't have motherboards in it from shut down companies. I'd be glad to explore your options with you.
ASpecialty4You.com
Nov 10, 2009 | Soltek SL-K890Pro-939 Motherboard
Ws 200s deleted files but still full
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Mar 20, 2008 | Olympus WS-200S
It doesn't turn on.
Here is the manual for it http://dlsvr01.asus.com/pub/ASUS/mb/sock370/815ep/cusl2-c/cusl2c-104.pdf Usually the light should stay on when its on and off when off, typically if it flashes, the powersupply itself is shutting off and coming back on. I would replace it first and go from there becaquse these LED's dont have a flash feature for this mobo.
Sep 17, 2007 | ASUS Intel 815E Chipset CUSL2-C...
ASUSTeK COMPUTER ASUS P8C WS - Motherboard - ATX - LGA1155 Socket - C216 - USB 3.0, Logo
162 people viewed this question
Top ASUSTeK COMPUTER Computers & Internet Experts
Steve Kozy
Steve Kozy
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Ron TheFlash Smith
Ron TheFlash Smith
Level 1 Expert
Are you an ASUSTeK COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
