Question about Archery
Sasheen Bow Maker S72
Plunger is stuck
2 Suggested Answers
  • 1739 Answers
SOURCE: 3M MAGIC BOW TYER BOW MAKER S-19 manual
The closest I could find was for the S-13. See here:
http://www.scribd.com/doc/57931282/Full-Manual
There are a number of videos on You-Tube that you may also find useful:
Trust these are helpful.
Posted on Mar 15, 2012
I press the lever down on Soda Stream and no carbonating stream, the three levels of light come on. Machine is a year old and tried 2 new canisters with no luck.
Put a finger up into the hole the CO2 canister screws into while you repeatedly push down on the carbonation button and up against the seat of the CO2 socket. You should feel a plunger moving up and down against the pressures of your finger and the button. If you don't feel this plunger, the SodaStream valve is either stuck or faulty. Make sure the CO2 cylinders are screwed up at least finger tight against the top of the socket.
Jun 06, 2015 | Sodastream Soda Stream Home Soda Maker...
Hi all, I have a Rowe AMI MM4 jukebox with the Rowe AMI 1100 mech. This was completly seized when i bought it, all seems to be working fine now except when returning the a side of a record, the toggle...
Hi Tim,
Do you have the manual? If you do check the adjustments on the gripper bow and the gearing adjustments whilst in transfer.
If you have greased the cam or trunion gears then remove any trace of lubrication from the gripper bow assembly other than putting some high melting point grease in the trunion casting pivot points.
Also check on the gripper bow (transfer arm & hub assembly) this plastic moulding that goes through the trunion has two flanges on it that guide the toggle pins to help turn the gripper bow staight before it goes back into the basket.
I hope this helps.
Regards
Alan
Alan Hood
ami-man
UK
Mar 26, 2013 | Audio Players & Recorders
Mar 14, 2012 | Kitchen Appliances - Others
Water not getting to the ice maker and water outlet. Put on a new line didnt; help. I didn't have water hooked to for a few years.
When both the ice maker and the water dispenser do not work the problem is usually the door / light switch. Check the door switch and make sure the light goes out when the door switch plunger is depressed. The light can work normally but the swtch can still have failed. The switch has one loveing tab on one side of it that you replease with a thin knife blade and coax the switch out of the cabinet. There are 3 contacts on the switch C (common) NC (Normally open) and NC (Normally closed) Read continuity as follows:
Common C to NC with the plunger extended.
Then with the plunger depressed C to NC.
It must read continuity for the ice maker and water dispenser to work.
This manual will help you:
http://applianceassistant.com/pdf/inDoorIceSystem.pdf
Just note the door switch plunger is taped down to perform any tests.
Thanks for choosing FixYa,
Kelly
Jul 05, 2011 | Amana Refrigerators
Cuisinart DGB-900BC filter basket brew pause spring came out. How do I fix it?
You can push the soft rubber stop or valve back on the plunger stem with the flat side down. It can pull out if you are rough with it or if the plunger gets stuck in your dishes drip rack. But if it is torn you need to order a new basket because I don't think the parts are sold separately.
Jan 12, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
I have frost build up where ice comes out of ice maker. The frost then clogs the shoot in door.
sounds like the ice flapper door is stuck open. Pretty common for GE refrigs to have the ice door solonoid and plunger get all rusty and need replacement
Nov 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker is stuck in crushed mode, will not change to cube.
there is a plunger in the rear of the cabinet that the ice bucket bail arm fits in. remove the bucket hold the door switch closed with the door open and make sure the cubed ice is selected and watch the plunger it should move up ward when you try and get ice. if it dooes not move it needs to be replaced if it does move jjust make sure the bail arm is properly inserted into the plunger assembly.aslo make sure that the plunger is in the down position first sometimes it will get stuck in the up position.
Sep 26, 2009 | Frigidaire PLHS267ZA Side by Side...
Archery Logo
103 people viewed this question
Top Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
