Protection light wont go off on my stav 3000 reciever
I have an optimus stav 3670 stereo reciever that wont turn on. I have located 3 fuses, all test good. No lights, click, or any sound or reaction when power button pushed. I'm hoping there is a 4th fuse...
Mike, sounds as if it's not getting voltage to the remote control receiver circuit? Meaning that there is a low voltage (5volts) that sits there and waits for the signal from your remote to turn the unit on. This is also through the front power switch which is also tied to your on-off power relay. I would check for 5 volts around that. More that likely you a 5 volt regulator shot. Hope this may help?
Nov 25, 2013 | Dryers
RCA STAV 3990 Power comes on but relay will not
Hi,your amp is going into protection mode.You need to have the amp module repaired or replaced
Nov 03, 2013 | Audio Players & Recorders
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Sep 07, 2010 | Optimus STAV-3770 Receiver
Optimus stav 3250 receiver - "protection" light keeps coming on. nothing blocking airvents. When I turn it past 10 it shorts out -
I have the same amp,, my trouble was a shorted out speaker,, wouldnt short out @ low volume,, crank it and the protection light would come on....
wasnt easy to find which of the 16 it was,,4 per cabnet X 4 quad set up ,, turned out to be a shorted tweeter...
Mar 01, 2010 | Televison & Video
Remote sensor is not working I assume, i have been unable to get any universal remote to work so I am thinking it is the actural sensor in the reciever. My receiver is not on the list. I inherited an...
I doubt that its the sensor. you can check at radio shack for a replacement remote. I have yet to see a universal remote that controls receivers. they would have to order it if available. use the catalog # on the back of the receiver (31-XXXX) or let me know the # and I can check into it for you. is it an stav3560 or 3250?
Nov 07, 2009 | Optimus STAV-3560
RCA STAV-3880 RECIEVER FOR CHEAP. I DOES NOT RECOGNIZE DIGITAL
I have found that on some units you unfortunately need the remote for more advanced settings. Sorry man.
Aug 01, 2009 | Audio Players & Recorders
Reciever connection problem
I am having problems connecting my Advent AW 10 wireless speakers up to my STAV 3770 reciever. What jacks to I connect to with my RCA cable to make a connection?
Dec 22, 2007 | Optimus STAV-3770 Receiver
Power off
check the fuses, there is one (fu1) behind the transformer and 2 under the transformer board (fu3, fu4)
Jan 28, 2007 | Optimus STAV-3560
 Grubhead
Grubhead
