Question about Refrigerators
I have a frigidaire side by side model frs23r4cb5...we recently moved and since the move the frig and freezer are getting cold but not cold enough...
    Genius:
  • 2,920 Answers
Did you tilt it at anytime and then plug it in?
Posted on Jan 12, 2009
FRIGIDAIRE FRS6HR4HW2 FRIDGE IS SOMEWHAT COOL BUT FREEZER IS SAME TEMP AS FRIDGE I HAVE POWER TO THE EVAP FAN BUT FAN IS NOT WORKING COULD THIS CAUSE THE FREEZER NOT TO GET COLD ENOUGH TO FREEZE
Yes, if your evap is fully frosted, and the fan is not working. The frosted evap will keep it cold but since the fan cant move the cold air from the evap it'll be cold, but not as cold as you'd like.
http://parts.sears.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FRS6HR4HW2/1428/0165000/R0607119/00005?shdMod=FRS6HR4HW2
there is the screen you need to order a new fan motor. option number 13 is the fan motor. lmk if u need more help!
Aug 05, 2013 | Frigidaire FRS26H5AS Side by Side...
Compressor buzzes loud & frig does not get cold
That can also mean that the starter is broken.which will be a cheaper fix than a new compressor.Also the capacitor can be broken and that will give the same results.
Please click HERE for drawing and parts( #30 is starter #55 capacitor)
Jul 28, 2008 | Frigidaire FRS26R4A Side by Side...
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
We recently moved and our Maytag French door ice maker was working fine when it was loaded on the moving truck, but when we plugged it back in it is no longer working at all. Any suggestions
after moving any frig / the fan underneath may have insulation in it or things bet bent causing the fan not to go . this would cause poor cooling and if freezer is not cold enough the ice maker would not work . ck the tempt in freezer / must be 15 deg or lower . and the fan could cause this problem also wiring on the bottom ..mm
Aug 03, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
I have a frigidaire gallery series frig side by side with ice and water in door. The frig part won't stay cold. It also seems to take long time to make ice. The frig part works ok for awhile and then...
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Oct 17, 2009 | Frigidaire FRS23KF7AB Side by Side...
The frig is not working but the freezer is going strong. Turned up the frig all the way but it does not seem to be doing anything. the tubes in the back of the frig are hot. I don't know anything about...
the tubes behind refrigerator are suppose to be hot.sounds like a defrost problem.turning up thethermostat will only make compressor run longer.cold air is made in freezer then gets moved over to the fridge side.your evaporator is more likely iced up.
Jun 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Jan 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frig is not getting cold!
How did you transport refrigerator? Standing straight up, or laying on its side???
Jul 14, 2008 | Frigidaire GLRT216TA Top Freezer...
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
