Question about Dryers
NEED ELECTRIC WIRING DIAGRAM FOR LE5700XPWO DRYER
SERIAL NR. M54146147
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What are you trying to do?
Posted on Dec 07, 2012
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
Posted on Sep 14, 2009
wfservices
  • 262 Answers
SOURCE: looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Posted on Feb 23, 2010
  • 177 Answers
SOURCE: Hello, Where can I get a wiring diagram for a
hi,
you probably won't have access to this as Miele do not share information on design or electrical diagrams. However if you own the unit and open up the front usually there is a diagram inside for technician use if required.
Hope this helps
Posted on May 25, 2010
livewire874
  • 618 Answers
SOURCE: need kenmore electric dryer model 110.66662500
Should find the wiring diagram under or in behind the control panel accessed by removing the 2 screws holding the panel down either in the front lower or rear lower end caps . If you can't see any screw heads there may be removable covers on the end caps from top to bottom . On some newer models you can insert a putty knife under the end caps on the front and depress a clip on either side and the whole control panel lifts and lays back. Before any of that check your fuses at the panel 2-- 30 amp
Posted on Nov 04, 2010
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Need a wiring diagram for Kenmore 110.63102101 dryer
Here you go, this is for both gas and electric units, since your unit is electric use the top diagram
Kenmore 6210 Dryer wiring diagram
May 01, 2010 | Kenmore 400 6942 Dryer
Need a wiring diagram for cde6000
There should be one iside the machine or hidden somewhere. Look under the control panel. Usually they are there. Let me know if you need any other help
Mar 29, 2009 | Crosley CDE6000 Electric Dryer
Need wiring diagram for model numbersoe4606ayw magtag dryer made by whirlpool
I have a link to the wiring diagram: Please let me know if you need anything else and kindly rate this Solution.
http://www.applianceaid.com/image/de312diagram.JPG
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
WIRING DIAGRAM
Oct 16, 2008 | Kenmore 64732 Electric Dryer
WIRING DIAGRAM
The manufacturer normally places a wiring diagram inside the operator console. Remove the back panel and there should be a diagram taped inside. Some of these diagrams will show two circuits. One is for a gas dryer, and one is for an electric dryer. Make sure you reference the correct one. I hope this helps you. If you need further assistance please let me know.
Aug 13, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
