Question about Refrigerators
Subzero r601 compressor not turning on
Got to house temp inside fridge said 79 (although cooler than that) compressor was warm - not hot, shut off breaker for about 15 min turned on breaker power to fridge again still not working
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check the relay on the compressor. Pull it off and shake it. If it rattles, it is bad.
Posted on Dec 07, 2012
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 105 Answers
SOURCE: subzero 361rfd fridge compressor wont stay runnig
It sounds like you have either a bad relay or a bad compressor. The fact that you hear the compressor try to start indicates that the control is good and there is voltage to the compressor. I would suspect the strat winding of the compressor but a meter would need to be used to determine is this is true.
Posted on Apr 07, 2009
farfield
  • 462 Answers
SOURCE: GE freezer/ bottom refrig won't turn on after short power outage
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Does it have a light inside? Is the bulb good? does the light go out when you push the button in? Why was power off? To change over to your name doesn't require the power co to kill power. At least it doesn't here. Try plugging in a lamp or other appliance to the outlet. Does this work?
It may have went into defrost and will take up to 30 minutes maybe longer with power applied before it comes back on.
Checking power inside the box next power to the compressor.
Yes power to compressor?
. To Decide if Either your compressor is broken inside or the start components are not working properly.
Parameters’ are as follows and must MUST be true before continuing:
1 Condencer coil (outside coil) Clean and open for a ir flow
2 Condensor Fan motor is running and turning at enough speed and correct direction.
3 Voltage to the compressor is correct and supplied.
4 Decide if the compressor is Hot or warm or cold to the touch for future reference.
Cold or Hot
Could it be the compressor not running or that it has overloaded?
If you suspect the compressor try to follow this to decide your next step:
These little helps allow you to get the compressor running or decide that it needs replacing
1 Ohm the compressor terminals to ground and across to each other.
A. If any read anything to ground the compressor is bad. No Need to go further.
B. If the compressor is hot and you read through some points on the compressor motor (pins or terminals) but not through others wait up to 24 hours for an internal over load to reset. Internal type, usually AC and larger Refrigeration Compressors. Smaller refrigerator type compressors have an external over load. After 24 hours off or yours has an external overload re-ohm and see if all have readings to each other. If these read open IE No resistance between each other the compressor is bad.
Results your looking for:
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
After 3 or 4 tries if the results don’t add up the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Get a new Start relay (start capacitor if so equipped) relay and overload (and run capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration..
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
No Power to compressor decide if you have a thermostat or a sensor. Thermostats have a knob and a small metal tube extending into the air on the refrigerator side. An electronic controls type has a sensor and a board that require a sheet of instructions to check out.
A thermostat type is easy to check put the wires together temporary and see if the compressor starts has voltage to it then, if so replace the thermostat.
I recomend if you have an electronic board and decide to replace it replace the sensor as well.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 18, 2009
  • 102 Answers
SOURCE: subzero 590 shut off can't find reset button to turn back on fridge
There is no reset. There is an on/off but it doesn't trip. You should check the breakers at the breaker box and then call for service if the one for the refr isn't tripped
Posted on Aug 05, 2009
  • 102 Answers
SOURCE: Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
After running for a few hours it gets hot and shuts down but runs fine every morning
Without more info I will have to give you several things to look at. Typically during the hot months rotary units experience temperature shut downs due to the following. Dirty oil coolers. Blowing them out with air my help some but ideally they need to be washed using a degreaser solution. Location. during the hot months poor air flow/ air removal may let heat from the compressor build up in or under the cover or room. This hot air gets drawn in by the compressor and raises the compressor temperature. The cycle continues until the compressor shuts down on high air temp. Maintenance. Poor maintenance on rotary screw compressors leads to shut downs on high temp, high air temps then play havoc on dryers which causes moisture in the air system. Maintenance items that need replacing regularly ( about 2000 hrs) oil filter, air filter, Depending on type of oil used change 2000 to 8000 hrs, seperator @ 8000 hrs. Also the amont element will cause high temps if bad. It is located where the three oil lines come together. There should be 4 screws that hold the cover on. the cover also has a hose connected to it and located close to the oil cooler. This amont element acts like the thermostat in your car. it lets oil bypass the oil cooler or causes more oil to go thru the cooler. the cooler oil and bypass oil mixes and maintains a certain temp. air end temp should run about 195 F and injected temp about 165 F. hope this helps. if you can give more detailed info I can get you closer to your problem.
Jul 13, 2011 | Air Tools & Compressors
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
Inside of fridge is hot. everthing is spoiled
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Magic Chef Refrigerators
To cool the compressor?? I do not have a problem, this is just a general discussion question I'm throwing out there. Every fridge I've ever owned, the compressor gets very warm/hot after running. I have a...
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Feb 22, 2009 | Frigidaire FRT15G4B Top Freezer...
Freezer and fresh food compartment are warm.
The fridge thermostat is faulty and not cutting in at the required temperature. Fridge stats are not easy to test, so the best way is to bypass the stat to see if the compressor starts. To bypass the stat first unplug the appliance and remove the stat housing from inside the fridge compartment, once you have removed the housing you will see the stat inside. Some stats have 2 terminals some have 3, whatever yours has you will need to connect the compressor wire ( Black) to the live wire (Red or White). When you have bypassed the stat plug the appliance back in and switch on, if the fridge starts up and runs ok you will need to purchase a new stat.
Jul 17, 2008 | Kenmore 57072 Side by Side Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
